AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Bolts in bom by dia and length
4 REPLIES 4
twdtech
1041 Views, 4 Replies
I am using Report Creator to generate a bulk BOM for the project. The BOM reports bolts as a number of sets based on flange size and rating. How can I get it to report the bolts by diameter and length. I am using Plant3D 2014 Ext 2.
4 REPLIES 4
patpat79
in reply to: twdtech
There is a query for bolt length and size
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
twdtech
in reply to: patpat79
I don't see any reports in the Report Creator that is specific to bolts. How do I access and use the query you mentioned?
You can create your own report configuration. Review the article at the link below if you haven’t had the chance. Also notice that there is a huge PDF file there to you might be interested in (Report_Designer).
About Report Creator
See also attached image.
(If this answers your question, please mark it as an Accepted Solution.)
Martin Stewart
AEC Support Specialist
patpat79
In our company, I've created a bulk items, and individual, pipes, valves, bolts, etc. Report separately. In the report create a new setup for the component you want
Best Regards,
Pat Andres
GHD Manila
”Boost
