Hello Friends, I am working on one project and facing some difficulties while extracting Isometrics. This project is in Metric unit. I assigned one spec "A1A" for RF, 150#. and assigned "Machine Bolt" for bolting as well as in Description I used "Machine bolt-description as per project" In BOM, I selected FULL FAMILY description for all components. But After extraction of ISO, Description of Bolt is coming like "PH IMPERIAL STUD BOLT" I am wondering if some one please explain me where I am going wrong. Please see attached snaps for more clarity.
@jabowabo wrote:
The bolt sets in your spec are not being used. Plant is instead selecting a bolt set from the 'Place Holder' spec. You need to check your connection definitions for the bolt set and verify they comply with the connection rules in the project settings.
Thanks jabowabo for your quick reply.
can you please elaborate this to me?
How i can assign to my spec? i used same connection which are available into ACAD supplied catalouges.
Hello Jabowabo,
@jabowabo wrote:
OOTB: http://en.m.wikipedia.org/wiki/Out_of_the_box_feature
Part description has no bearing on connectivity. Please check the three items I described above - they must be the same on each port to be connected.
Thanks for your help. and now I can able to see my DESC fro Bolts which I had assigned for BOLT SET.
I was trying to use LUG bolt instead of simple BOLT.
But now I have observe new error for same Bolts.
Please see attached Snaps.
I am using all CATS supplied for ACAD PLANT 3D.
but still i can see two different BOLT len for a single Valve at both the ends.
If you see Bolts for assigned Valve, then those are with same sizes but different Length (See snap-2).
I am bit confuse and not able to solve where from it can be fix.
I confirmd FLan THK which is same for both Flanges as well as for Valve Also.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Best Regards,
Pat Andres
GHD Manila
Best Regards,
Pat Andres
GHD Manila
Best Regards,
Pat Andres
GHD Manila
Best Regards,
Pat Andres
GHD Manila
Best Regards,
Pat Andres
GHD Manila
Best Regards,
Pat Andres
GHD Manila
Best Regards,
Pat Andres
GHD Manila
