For Pure Metric Project, Bolt sets are designated in BOM of Isometric drawing is 10x150 (bolt size in mm x length in mm). Can I designate these bolt set like M10x150 LG.
Solved by bapan_b. Go to Solution.
Solved by Dan.Scales. Go to Solution.
I will log a feature enhancement request for the ability to add a prefix and suffix to the bolt sizes in the BOM.
Dan
It is possible to get the result you want by adding two "styles" in the isoconfig.xml. One for the bolt diameter and one bolt length and then setting the relevant styles to the BoltDiameterStyle and BoltLengthStyle:
The above change will give the following result in the BOM:
Thanks goes my colleague Jarrod Mudford for this tip!
I hope this helps.
Dan
There is one other way
Find the file "BoltSizeMappings.xml" (under folder [Isometric])
Change every "M#" to "MM#"
