AutoCAD Plant 3D Forum
Bolt set bubble leader needs to be longer - Plant3D 2012
5 REPLIES 5
dennis
620 Views, 5 Replies
I have created a pipe spec with cast-on flanges.  The bolt set is coming in as expected, however the red-bubble is buried inside the joint connection rather than sticking out some so that I can see it and easily select it.  How can I fix this so that when Plant3D makes the connection, I can see easily the boltset bubble?
5 REPLIES 5
quentin.contreras
in reply to: dennis
Could you possibly include a screen shot that way I can see exactly what you are seeing?
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
TomislavGolubovic
in reply to: dennis
The bolt symbol in the 3D model?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
dennis
in reply to: dennis
I added in a screen shot that shows the bubble.  I used the IsolateObject light-bulb to turn off the fittings to expose the bubble leader.  I want that bubble to be below the fitting so that I can select it without isolating off the fitting.  Yes, you will see in the attachment that I am talking about the 3D model.
Thanks for the help,
quentin.contreras
in reply to: dennis
Have you made any progess in resolving the problem yet? I am still doing some looking as to if there is a feature that will allow you to change the size, but have not come up with anything yet. I am still searching though...
Quentin Contreras
I think the nominal diameter and / or the the MatchingPipeOD properties of the BoltSet are used to determine the length to draw the set.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
”Boost
