AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Bolt Long Description
4 REPLIES 4
1181 Views, 4 Replies
Does anyone know how to modify the Long Description to display the Long Description (Size) with specs including bolt size and length? Currently when the BOM is constructed it shows the Long Description using the Family Description rather than Size Description.
Help would really be appreciated. Especially coz I'm a trainee.
4 REPLIES 4
karthik.nathan
In Plant 3D, you can go into 'Project Setup -> Isometric DWG Settings -> Title Block and Settings', then click the 'Setup Title Block' button which will let you set up the title block. Once you're there, click 'Table Setup' on the Ribbon above, then go to the 'Settings' tab of the dialog that was just opened. There is a combo box for BOM descriptions there where the default value is (Family). You can change that to (Size) and save it.
The isos will come out the way you want then. Hope that helps.
-Karthik
in reply to: karthik.nathan
Thanks for the suggestion but I need only the Bolts long description to change in the BOM not the other components. is there a way for just the bolts to change?
Vicky.Wu
User could customize long description via lds file.
Create lds file in Spec Editor:
Spe Editor> Specs Menu>Batch Assign Long Description Styles>Edit Long Description Style> select Bolt Set
Then you could customize the description in Long description formular editor grid and save as lds file.
Apply lds file in Project Setup:
Project Setup>Setup Title block> Table setup>Settings Tab,check Use Custom Descriptions, select lds file created.
Vicky
Autodesk Plant Solutions
Wolfanator
in reply to: Vicky.Wu
Hi Vicky,
I'm currently writing spec in AP3D 2018 and I am looking at the bolt set in my spec editor , I see the long description (size) it has everything I need , description, length , c/ nuts and material code etc
I am wanting to use the long description (size) for my assign long description , how come when Ai want to add row , you cant find that property Name ??
any help would be greatly appreciated
Ian
”Boost
