I am currently working in Autodesk Plant Design Suite Premium 2012 and im reading up on some solved bill of material issues. they are all saying to go to the report creator and pick the plant 3d BOM. that is where my problem comes in to play. My report creator does not have this option. is this something i need to create or is there a service pack that adds this or maybe some hot fix or something i didnt do correctly in the install? Please help.
Solved by KenFauver. Go to Solution.
Is there a way to quickly generate a simple BOM excel file from the command line? The report designer is very difficult to use. Is there a third party software and plugin that allows us to do this?
See attached for example of what we need... it's very basic.
Thanks!
@dpappan, have you used the Data Manager from the ribbon inside Plant3D? That will export a list in Excel for you
