AutoCAD Plant 3D General DIscussion
Distinguished Contributor
7 Kudos
Post 1 of 7
Basic doubts about AutoCAD Plant 3D
564 Views, 6 Replies
02-20-2013 11:17 PM
We have few basic doubts,which needs to be sorted out for AutoCAD Plant 3D suite:
1.      How to import files from other softwares like TSI or revit
2.      What are the export /Import methods and settings
3.      How to edit existing database depending on project requirement
4.      P&ID diagram settings and editing
5.      How to create equipment model based on project submittals
6.      What is production ISO
7.      How to create and edit shop drawings
7 Kudos
Post 2 of 7
Betreff: Basic doubts about AutoCAD Plant 3D
02-21-2013 12:39 AM in reply to: RNDPIS
a lot of questions .... mayby its time to vist a training  or read on of the books ...
cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Valued Mentor
30 Kudos
Post 3 of 7
02-21-2013 02:16 AM in reply to: cadwomen
Completely agreed!
You should start a proper training or go through a training book before start asking these kind of questions!
All of your questions will be answered than.
Attila Vallyon
7 Kudos
Post 4 of 7
Re: Basic doubts about AutoCAD Plant 3D
02-21-2013 02:33 AM in reply to: RNDPIS
Thank for the thaught. If you have the answer then it would be very helpful for both of us. We are waiting for your valuable reply:smileyhappy:
501 Kudos
Post 5 of 7
02-21-2013 12:05 PM in reply to: RNDPIS
Thats a little too extensive to be able to cover properly in an internet forum.  If you haven't already, get a reseller to come in for a demonstration.  Make sure they are aware of your specific requirements (such as importing from Revit, which *all* programs have problems with) so they can tailor the presentation properly.  In addition maintain industry contacts with other users in your area.  There may be other users/companies who would be willing to visit or let you visit for a first-hand non-sales review.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Active Contributor
9 Kudos
Post 6 of 7
02-25-2013 05:46 PM in reply to: RNDPIS
Agreed, these are questions suited for demos and training. They are lengthy How To questions. The answer to all of these would be to contact a reseller and schedule a demo, probably explain that you have some detailed quesitons and they will be able to tailor a demo, or schedule a longer demo with time for indepth Q&A.
Employee
51 Kudos
Post 7 of 7
02-25-2013 07:01 PM in reply to: RNDPIS
I'll help with some answers
Q1. How to import files from other softwares like TSI or revit
A1. Not knowing what TSI is, I can't answer that. In regards to Revit, you would export the Revit model to .dwg format, and use that as an XREF against your piping model.
Q2. What are the export /Import methods and settings
A2. In regards to what? DWG's or database?
Q3. How to edit existing database depending on project requirement
A3. Not 100% sure on what you're asking here. If the project changes? Project variables? Specs? Models?
Q4. P&ID diagram settings and editing
A4. A draftsperson edits and creates P&ID's inside the project.
Q5. How to create equipment model based on project submittals
A5: There are three ways of creating equipment. The first is by using the form provided in the software to create equipment, in which you can export templates. The second is to convert an AutoCAD 3D Model of the part. The third way is to convert an Inventor .adsk file to a piece of equipment.
Q6. What is production ISO
A6. An Isometric drawing that goes to a factory to be built. Its a 2d representation of the pipe run from the model, it also contains a Bill of Materials.
Q7. How to create and edit shop drawings
A7. Shop drawings of what?
Hope this helps.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
