AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
bad initialization of network paths P3D 2013
9 REPLIES 9
Message 1 of 10
SamScopeo
751 Views, 9 Replies
Context :
We work in network :
- P3D projets,
- project's specs
- SharedContentFolder with catalogs
are on our server.
Description of observations
At each (re)start of user's computer, when the user launchs P3D, the networks path are not seen as connected by P3D.(red crosses on network letters appear in P3D file browe window). And P3D is not able to find by itself any network file/folder
However, in Windows file browser the network letters are correctly connected.
After the user had browse in P3D file browser, the network letters become connected and P3D is able to find the files/folders
See JPEG attached
Consequences :
- The launch of P3D is very very long : P3D try to find the path of the last project open, and it can't,
- the PLANTCONTENTFOLDER is redirected to local path "C:\AutoCAD Plant 3D 2013 Content"
- the user have to open the project manualy
- the user have to redirect the PLANTCONTENTFOLDER  to server with the command PLANTMODIFYSHAREDCONTENTFOLDER
Any solution is welcome ! Thanks
Sam
9 REPLIES 9
Message 2 of 10
Dan.Scales
in reply to: SamScopeo
What kind of drive is the network share? Is it a Windows box or some type of NAS drive?
Dan
Dan Scales
Message 3 of 10
eadkins73
in reply to: Dan.Scales
I've had that problem too.  I found that if I opened the Drive in Windows Explorer before launching P3D it is able to find the drive.
Ed
Ed Adkins
EA2 Engineering
www.ea2eng.com
Message 4 of 10
SamScopeo
Our drives are some SMB Windows 2008 R2 shared folder (on a dedicated file server).
On user's computers it's deployed using GPO, as network drives (Windows 7).
SamScopeo
Message 5 of 10
SamScopeo
in reply to: eadkins73
Yes, I've figured that out too. But this is no solution. I can't tell users they have to open the drive before launch P3D.
I'm looking for an automated solution 🙂
SamScopeo
Message 6 of 10
Dan.Scales
If you map the drives manually without using GPO to do it does the issue occur?
Dan
Dan Scales
Message 7 of 10
SamScopeo
Hi Dan
I tried map the drives manually : same issue 😞
Sam
Message 8 of 10
Dan.Scales
Hi Sam,
I think the next thing to look at is permissions.
If you assign the user full administrator permission does the same happen?
Dan
Dan Scales
Message 9 of 10
SamScopeo
Hi Dan,
I have already  full administrator permissions on my workstation
Sam
Message 10 of 10
Dan.Scales
Hi Sam,
If you open the project.xml files does the fileName and uncFileName path look correct?
Dan
Dan Scales
”Boost
