does anyone know how to change the project setup in order to create an OPC with an additional unique number corresponding with the connected OPC on another P&ID sheet. The number should automatically raise by 1.
Attached a screenshot of an OPC with the (example) number.
At the moment i only use 1 type OPC, so not an off page connector and an on page connector.
regards, Jan
Hi Jan,
Off Page Connectors are not a tagged component so there is no means I know of to increment their number through DrawingAutoGenProperties.
What I have done and may be of help is to set the Off Page Connector number to the Pipe Line Group - Line Number as follows:
- Pipe Line Segment has new property called OffPageConnectNumber
- This property acquires Line Number from Pipe Line Group
- Connector Number can now acquire Pipe Line Segment OffPageConnectNumber.
See attached.
Bruce
