when I use mixed spec, where pipes are ASME and flanges DIN. I allow all mixed connections. And when I want to connect BV end of DIN flange with PL end of ASME pipe it's connected ok. But the problem is in the AutoFlange connection. Because in this case it's not connected.
Any solution?
The solution is to modificate Connection xml file on the project.
