AutoCAD Plant 3D General DIscussion
Valued Mentor
ybogdanov
Message 1 of 2 (352 Views)
AutoFlange with DIN flange and ASME pipe
352 Views, 1 Replies
10-01-2012 08:06 AM
 when I use mixed spec, where pipes are ASME and flanges DIN. I allow all mixed connections. And when I want to connect BV end of DIN flange with PL end of ASME pipe it's connected ok. But the problem is in the AutoFlange connection. Because in this case it's not connected.
Any solution?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Valued Mentor
ybogdanov
Message 2 of 2 (352 Views)
Re: AutoFlange with DIN flange and ASME pipe
10-01-2012 08:37 AM in reply to: ybogdanov
The solution is to modificate Connection xml file on the project.
Yury Bogdanov
Barcelona (Spain)
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
