AutoCAD Plant 3D Forum
AutoCD Plant 3D - ISO BOM Configuration
4 REPLIES 4
CaveManCode
1593 Views, 4 Replies
Hi All
In the Bill Of Materials Table is there a possible way to change the Text from CAPS to smalls?
As well as in the size field to change the delimiter "X" to "x", everytime w have to edit this as this is what the client wants and is paying for? Each time our team has to manually edit this?
Have already edited the IsoConfig.xml file
or maybe i did not have the correct details of what to config . . .
If you could help would greatly appreciate
Thanks in Advance
Best Regards
Richad
4 REPLIES 4
mrc9961
in reply to: CaveManCode
in your title block setup double click the field (text) and under format it gives you case options
CaveManCode
Hi There
Thanks for the feed back, but these ooptions or properties on the Table do not function.
When the isogens are spooled, somehow the default setting is all caps lock, no matter how you have configured the table in the iso.dwt file?
so everthing comes out in caps?
Appreciate the reply - maybe there is some other setting that would allow the iso.dwt table to take preference?
Regards
Richard
malreid
Check the very first lines of isocong.xml for ForceUpcase and set the value to "false".
This will fix your size delimiter problem, but may mean that item descriptions come through in mixed case if that is how they are enetered in the catalogs.
eljer0n.bma
Hi all!
I understand that it may be too late, but if anyone needs answer for topicstarter's question it is in the picture below. You just have to open isoconfig.xml find marked row and change the value of delimiter to required one.
Vladimir
”Boost
