AutoCAD Plant 3D General DIscussion
hoangvuminh
Message 1 of 2 (114 Views)
Autocad Plant3D - 2011 - Test German Version
114 Views, 1 Replies
09-23-2011 01:30 AM
Hi all ,
I want to develop a net assembly for Autocad Plant3D - 2011 - Test German Version. When i tried to access the PnpTable with name "PnPDrawings" so that i can get information of the drawings. But i can not get it do you know how ?
Employee
RSFAdsk
Message 2 of 2 (100 Views)
Re: Autocad Plant3D - 2011 - Test German Version
09-23-2011 11:58 AM in reply to: hoangvuminh
I think the code below should allow you  to get informatuion from the PnPDrawings table:
   Project prj = PnPProjectUtils.GetProjectPartForCurrentDocument();
   DataLinksManagerdlm = prj.DataLinksManager;
   PnPDatabasedb = dlm.GetPnPDatabase();
   PnPTable tblDwg = db.Tables["PnPDrawings"];
   //Plant SDK 2012 use Select
   PnPRow[] rows = tblDwg.Select();
   dumpRows(rows);
//Utility
void dumpRows(PnPRow[] rows)
   foreach (PnPRow r inrows)
      dumpRow(r);
void dumpRow(PnPRowr)
   Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
   ed.WriteMessage("\n ");
   //For every column in the fow list the value.
   foreach (PnPColumn c inr.Table.AllColumns)
      objectval = r[c];
      ed.WriteMessage(
      string.Format("{0}={1} ", c.Name, val));
Richard Frank
AEC Plant Solutions
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
