AutoCAD Plant 3D General DIscussion
Active Contributor
CaveManCode
Message 1 of 7 (1,901 Views)
AutoCAD Plant 3D - Structure - Add New Items
1901 Views, 6 Replies
10-09-2012 03:31 AM
Good Day All
Does anyone have a tutorial on how one adds different shape standards to AutoCADPlant 3D structural.
We want to add our Native SANS steel sections to AutoCAD Plant 3D?
Any advice, tuturial reference, assistance welcome
Thanks in advamce
Regards
Richard
There is available Content Packs on Plant Exchange you can download. But at the moment there is now way to publish your own Structural Members. From Plant Exchange you can request a Content Pack and it will be placed in a list to be created by Autodesk.
Employee
JarrodMudford
Message 2 of 7 (1,882 Views)
Re: AutoCAD Plant 3D - Structure - Add New Items
10-09-2012 01:34 PM in reply to: CaveManCode
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Active Contributor
CaveManCode
Message 3 of 7 (1,852 Views)
10-11-2012 01:16 AM in reply to: JarrodMudford
Thanks for the information
Unfortunatly did not find any content packs for SANS steel sections.
I see you work for Autodesk, here is a requsest . . .
Can you send me the Table, File and Data Hierarchical Structure so that i can create a .Net User Interface to add data?
Did you hear that Mercedes Benz now sells cars without steering wheels? They tried to use AutoDesk Software but could not add the specifications in to design the Steering Wheel!!
Appreciate your reply
Best Regards
Richard
New Member
clifford
Message 4 of 7 (1,310 Views)
06-11-2013 05:57 AM in reply to: CaveManCode
Hi Richard,
Was wondering if you came right with the SA steel content.  i'm in the same boat.
Active Contributor
CaveManCode
Message 5 of 7 (1,305 Views)
06-11-2013 06:31 AM in reply to: CaveManCode
Hi Clifford
Sadly Not, We used ASD (AutoCAD Structural Detailing) instead.
I did hear that Modena compiled the steel sections for SANS in Plant 3D "say this under correction" as i have never checked this, but as i understood this was for retail from them?
On the download center i only came accross someone that had edited the Australian Steel sections released 2010, i did email the person but to no avail, did not recieve a reply with the method in which it could be done?
Best of luck to come right with this.
Regards
Richard
New Member
clifford
Message 6 of 7 (1,280 Views)
06-13-2013 01:01 AM in reply to: CaveManCode
Description: Visit our website
Hi Richard,
Thanks for the response. I'm new to the Plant Design Suite, and I must say
the lack of SA content is frustrating.
Where did you get your SA content for ASD?
Kind regards
Clifford McClure
TDF Projects and Equipment
P.O. Box 20758
Durban North
KZN, 4016
South Africa
Tel + 27 31 9103527
Tel/Fax + 27 31 5727652
Fax 0865399982
Cell + 27 83 3090623
E-mail clifford@tdfprojects.com
Website: http://www.tdfprojects.com
Active Contributor
CaveManCode
Message 7 of 7 (1,277 Views)
06-13-2013 01:46 AM in reply to: clifford
Hi There
To find the SANS sections in ASD please review Image
Once this is loaded you can select the various steel section required.
The negatives using ASD is that the geometry is NOT 3D solids, The ASD model has to be exported as a .SAT to be able to get used in the Orthographic DWG in plant 3D. Review image below as well . . .
ASD has got a utility to export to ACIS, but we found that this would also export non solid objects. with these entities in the model in Plant 3D, this caused the Orthographic to crash? This was not consistent however . . .
The better alternative was to use the File > Export > Other Formats > SAT (This only exports true 3D solid objects.)
As you can see there is a little work around for this . . . but ASD work fast and effctive for generating Steel Structures for plant design.
If someone reads this and has better solutions - please post comments.
Cheers Mate
Regards
Richard
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
