Good Day All
Does anyone have a tutorial on how one adds different shape standards to AutoCADPlant 3D structural.
We want to add our Native SANS steel sections to AutoCAD Plant 3D?
Any advice, tuturial reference, assistance welcome
Thanks in advamce
Regards
Richard
Solved by JarrodMudford. Go to Solution.
There is available Content Packs on Plant Exchange you can download. But at the moment there is now way to publish your own Structural Members. From Plant Exchange you can request a Content Pack and it will be placed in a list to be created by Autodesk.
Thanks for the information
Unfortunatly did not find any content packs for SANS steel sections.
I see you work for Autodesk, here is a requsest . . .
Can you send me the Table, File and Data Hierarchical Structure so that i can create a .Net User Interface to add data?
Did you hear that Mercedes Benz now sells cars without steering wheels? They tried to use AutoDesk Software but could not add the specifications in to design the Steering Wheel!!
Appreciate your reply
Best Regards
Richard
Hi Clifford
Sadly Not, We used ASD (AutoCAD Structural Detailing) instead.
I did hear that Modena compiled the steel sections for SANS in Plant 3D "say this under correction" as i have never checked this, but as i understood this was for retail from them?
On the download center i only came accross someone that had edited the Australian Steel sections released 2010, i did email the person but to no avail, did not recieve a reply with the method in which it could be done?
Best of luck to come right with this.
Regards
Richard
Hi There
To find the SANS sections in ASD please review Image
Once this is loaded you can select the various steel section required.
The negatives using ASD is that the geometry is NOT 3D solids, The ASD model has to be exported as a .SAT to be able to get used in the Orthographic DWG in plant 3D. Review image below as well . . .
ASD has got a utility to export to ACIS, but we found that this would also export non solid objects. with these entities in the model in Plant 3D, this caused the Orthographic to crash? This was not consistent however . . .
The better alternative was to use the File > Export > Other Formats > SAT (This only exports true 3D solid objects.)
As you can see there is a little work around for this . . . but ASD work fast and effctive for generating Steel Structures for plant design.
If someone reads this and has better solutions - please post comments.
Cheers Mate
Regards
Richard
Hi RSA,
Modena as a Gold Partner to Autodesk has a SANS Steel Library for customers who purchase Plant Design Suite.
To service those customers outside of a direct purchase we offer the same libraries for subscriptions or direct purchase.
Please contact a sales representative or support @ modena.co.za for more details.
Hi Gareth
is this SANS library still available? i called Modena today and they dont seem to know what im talking about.
Dear Autodesk,
I have been using Plant 3D since 2012 and cannot understand why 10 years later there is not a more comprehensive steel library for Plant 3D!? Why should we the end users pay for such content when competitors include it free of charge? At the very least enable users to create these libraries for themselves!
It still boggles the mind...
Hi m.dupreez,
I am new in Plant3D. I started my job in September '22. I worked nearly 9 years for administration for
CADISON (www.cadison.com). Before that I worked for Plant and Project Engineering.
Yesterday I added Steel Member (new size) and also Material. The answer / solution comes more or less from here:
How to add a custom shape size for a structural member in AutoCAD Plant 3D | AutoCAD Plant 3D 2021 |...
I am really sure, that's also possible to add a new basic shape that is not available right now.
It could be with seperate PYTHON / XML script !?
Udo Hoffmann
