AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Autocad Plant 3D Flow Arrows
5 REPLIES 5
brian
840 Views, 5 Replies
We are using AutoCAD plant for a project.  When we go to plot the flow arrows on the P&IDs shown in the program are not showing up on the plot preview.  Is there any reason this would happen?  Please see attached and advise!!! Thanks.
5 REPLIES 5
ybogdanov
in reply to: brian
The layer of arrows is desable to printed. Probe to change it to layer of lines.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
brian
in reply to: ybogdanov
Hi yury.  Thanks for the input.  Both the arrows and the lines are on the primary layer.  So unfortunatley this doesnt solve our issue.
brian
in reply to: brian
both the line and arrow are a sline if that helps.
ybogdanov
in reply to: brian
can you attach the dwg for view it?
Yury Bogdanov
Barcelona (Spain)
mgalicki
in reply to: brian
Is it also possible to have arrows to show flow in both directions?
Mark
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
”Boost
