Sir I want to installed AutoCAD Plant 3D. But the setup reverses on installing AutoCAD plant 3D Product. The logfile is given below. I will be very thankful to you if you provide me the solution. I really want to install the software.
2014/7/20:22:22:57 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/20:22:22:57 Mashhud STALLIONS Path_Length: 157 2014/7/20:22:22:57 Mashhud STALLIONS Current Directory I: 2014/7/20:22:22:57 Mashhud STALLIONS Launch 2014/7/20:22:22:57 Mashhud STALLIONS CommandLine 2014/7/20:22:22:57 Mashhud STALLIONS Path_Length: 157 2014/7/20:22:22:57 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI6EC8.tmp 2014/7/20:22:23:15 Mashhud STALLIONS === Setup ended === 2014/7/20:22:23:04 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/20:22:23:04 Mashhud STALLIONS Path_Length: 157 2014/7/20:22:23:04 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI6EC8.tmp 2014/7/20:22:23:04 Mashhud STALLIONS Launch 2014/7/20:22:23:05 Mashhud STALLIONS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mashhud\AppData\Local\Temp\_AI6EC8.tmp\Setup\AcSetup.dll 2014/7/20:22:23:05 Mashhud STALLIONS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/7/20:22:23:15 Mashhud STALLIONS PageOpen LaunchDialog 2014/7/20:22:23:18 Mashhud STALLIONS PageOpen LicenseDialog 2014/7/20:22:23:27 Mashhud STALLIONS PageOpen ProductInfoDialog 2014/7/20:22:24:11 Mashhud STALLIONS PageOpen ProductSelectionDialog2 2014/7/20:22:24:12 Mashhud STALLIONS PageOpen FullProgressDialog 2014/7/20:22:24:12 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "I:\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2014/7/20:22:24:31 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2014/7/20:22:24:31 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "I:\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2014/7/20:22:25:21 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2014/7/20:22:25:21 Mashhud STALLIONS Installing DirectX Runtime: "I:\3rdParty\DirectX\DXSETUP.exe" /silent 2014/7/20:22:26:33 Mashhud STALLIONS Install DirectX Runtime Succeeded 2014/7/20:22:26:34 Mashhud STALLIONS Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI6EC8.tmp\Media.mst" 2014/7/20:22:27:19 Mashhud STALLIONS Install Autodesk Material Library 2015 Succeeded 2014/7/20:22:27:19 Mashhud STALLIONS Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI6EC8.tmp\Media.mst" 2014/7/20:22:27:41 Mashhud STALLIONS Install Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/20:22:27:42 Mashhud STALLIONS Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS=I:\x64\en-us\Tools\snap\ContentService.mst;C:\Users\Mashhud\AppData\Local\Temp\_AI6EC8.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/20:22:28:03 Mashhud STALLIONS Install Autodesk Content Service Succeeded 2014/7/20:22:28:04 Mashhud STALLIONS Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI6EC8.tmp\Media.mst" 2014/7/20:22:28:11 Mashhud STALLIONS Install Autodesk Content Service Language Pack Succeeded 2014/7/20:22:28:11 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015: TRANSFORMS="I:\x64\en-us\PLNT3D\PLNT3D.mst;C:\Users\Mashhud\AppData\Local\Temp\_AI6EC8.tmp\x64\PLNT3D\PLNT3D-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/20:22:37:44 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Succeeded 2014/7/20:22:37:47 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015 Language Pack: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI6EC8.tmp\_laF9CE.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/20:22:39:03 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Language Pack Succeeded 2014/7/20:22:39:04 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015 Product Specific Pack: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI6EC8.tmp\_laF9CE.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/20:22:39:39 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Product Specific Pack Failed Installation aborted, Result=1602 2014/7/20:22:40:18 Mashhud STALLIONS Rollback Autodesk® AutoCAD® Plant 3D 2015 Language Pack Succeeded 2014/7/20:22:43:10 Mashhud STALLIONS Rollback Autodesk® AutoCAD® Plant 3D 2015 Succeeded 2014/7/20:22:43:13 Mashhud STALLIONS Rollback Autodesk Content Service Language Pack Succeeded 2014/7/20:22:43:31 Mashhud STALLIONS Rollback Autodesk Content Service Succeeded 2014/7/20:22:44:28 Mashhud STALLIONS Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/20:22:45:52 Mashhud STALLIONS Rollback Autodesk Material Library 2015 Succeeded 2014/7/20:22:45:52 Mashhud STALLIONS Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2014/7/20:22:45:53 Mashhud STALLIONS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2014/7/20:22:45:53 Mashhud STALLIONS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619 2014/7/20:22:45:55 Mashhud STALLIONS PageOpen InstallCompleteDialog 2014/7/20:22:46:05 Mashhud STALLIONS === Setup ended === 2014/7/20:22:50:45 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/20:22:50:45 Mashhud STALLIONS Path_Length: 105 2014/7/20:22:50:45 Mashhud STALLIONS Current Directory I:\x64\en-us\PLNT3D 2014/7/20:22:50:45 Mashhud STALLIONS Launch 2014/7/20:22:50:45 Mashhud STALLIONS CommandLine 2014/7/20:22:50:45 Mashhud STALLIONS Path_Length: 105 2014/7/20:22:50:45 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AIE426.tmp 2014/7/20:22:51:08 Mashhud STALLIONS === Setup ended === 2014/7/20:22:50:56 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/20:22:50:56 Mashhud STALLIONS Path_Length: 105 2014/7/20:22:50:56 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AIE426.tmp 2014/7/20:22:50:56 Mashhud STALLIONS Launch 2014/7/20:22:50:57 Mashhud STALLIONS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mashhud\AppData\Local\Temp\_AIE426.tmp\Setup\AcSetup.dll 2014/7/20:22:50:57 Mashhud STALLIONS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/7/20:22:50:57 Mashhud STALLIONS PageOpen LaunchDialog 2014/7/20:22:51:14 Mashhud STALLIONS PageOpen ProductSelectionDialog2 2014/7/20:22:51:27 Mashhud STALLIONS PageOpen LaunchDialog 2014/7/20:22:51:30 Mashhud STALLIONS PageOpen BeginDeploymentDialog 2014/7/20:22:51:30 Mashhud STALLIONS CBeginDeploymentDialog:nInitDialog reads PATH_LENGTH: 105 2014/7/20:22:51:42 Mashhud STALLIONS === Setup ended === 2014/7/20:22:52:09 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/20:22:52:09 Mashhud STALLIONS Path_Length: 157 2014/7/20:22:52:09 Mashhud STALLIONS Current Directory I: 2014/7/20:22:52:09 Mashhud STALLIONS Launch 2014/7/20:22:52:09 Mashhud STALLIONS CommandLine 2014/7/20:22:52:09 Mashhud STALLIONS Path_Length: 157 2014/7/20:22:52:09 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI29BE.tmp 2014/7/20:22:52:20 Mashhud STALLIONS === Setup ended === 2014/7/20:22:52:13 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/20:22:52:13 Mashhud STALLIONS Path_Length: 157 2014/7/20:22:52:13 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI29BE.tmp 2014/7/20:22:52:13 Mashhud STALLIONS Launch 2014/7/20:22:52:14 Mashhud STALLIONS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mashhud\AppData\Local\Temp\_AI29BE.tmp\Setup\AcSetup.dll 2014/7/20:22:52:14 Mashhud STALLIONS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/7/20:22:52:19 Mashhud STALLIONS PageOpen LaunchDialog 2014/7/20:22:52:33 Mashhud STALLIONS PageOpen LicenseDialog 2014/7/20:22:52:33 Mashhud STALLIONS PageOpen ProductSelectionDialog2 2014/7/20:22:53:50 Mashhud STALLIONS PageOpen LicenseDialog 2014/7/20:22:53:50 Mashhud STALLIONS PageOpen LaunchDialog 2014/7/20:22:53:53 Mashhud STALLIONS PageOpen LicenseDialog 2014/7/20:22:53:57 Mashhud STALLIONS PageOpen ProductInfoDialog 2014/7/20:22:54:33 Mashhud STALLIONS PageOpen ProductSelectionDialog2 2014/7/20:22:55:12 Mashhud STALLIONS PageOpen FullProgressDialog 2014/7/20:22:55:12 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "I:\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2014/7/20:22:55:34 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2014/7/20:22:55:34 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "I:\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2014/7/20:22:56:28 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2014/7/20:22:56:28 Mashhud STALLIONS Installing DirectX Runtime: "I:\3rdParty\DirectX\DXSETUP.exe" /silent 2014/7/20:22:57:38 Mashhud STALLIONS Install DirectX Runtime Succeeded 2014/7/20:22:57:39 Mashhud STALLIONS Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI29BE.tmp\Media.mst" 2014/7/20:22:58:26 Mashhud STALLIONS Install Autodesk Material Library 2015 Succeeded 2014/7/20:22:58:27 Mashhud STALLIONS Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI29BE.tmp\Media.mst" 2014/7/20:22:59:26 Mashhud STALLIONS Install Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/20:22:59:28 Mashhud STALLIONS Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS=I:\x64\en-us\Tools\snap\ContentService.mst;C:\Users\Mashhud\AppData\Local\Temp\_AI29BE.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/20:22:59:46 Mashhud STALLIONS Install Autodesk Content Service Succeeded 2014/7/20:22:59:46 Mashhud STALLIONS Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI29BE.tmp\Media.mst" 2014/7/20:22:59:55 Mashhud STALLIONS Install Autodesk Content Service Language Pack Succeeded 2014/7/20:22:59:55 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015: TRANSFORMS="I:\x64\en-us\PLNT3D\PLNT3D.mst;C:\Users\Mashhud\AppData\Local\Temp\_AI29BE.tmp\x64\PLNT3D\PLNT3D-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/20:23:08:28 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Succeeded 2014/7/20:23:08:29 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015 Language Pack: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI29BE.tmp\_la1D28.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/20:23:09:45 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Language Pack Succeeded 2014/7/20:23:09:45 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015 Product Specific Pack: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI29BE.tmp\_la1D28.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/20:23:10:14 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Product Specific Pack Failed Installation aborted, Result=1602 2014/7/20:23:10:43 Mashhud STALLIONS Rollback Autodesk® AutoCAD® Plant 3D 2015 Language Pack Succeeded 2014/7/20:23:13:31 Mashhud STALLIONS Rollback Autodesk® AutoCAD® Plant 3D 2015 Succeeded 2014/7/20:23:13:34 Mashhud STALLIONS Rollback Autodesk Content Service Language Pack Succeeded 2014/7/20:23:14:01 Mashhud STALLIONS Rollback Autodesk Content Service Succeeded 2014/7/20:23:14:39 Mashhud STALLIONS Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/20:23:15:35 Mashhud STALLIONS Rollback Autodesk Material Library 2015 Succeeded 2014/7/20:23:15:35 Mashhud STALLIONS Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2014/7/20:23:15:35 Mashhud STALLIONS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2014/7/20:23:15:35 Mashhud STALLIONS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619 2014/7/20:23:15:43 Mashhud STALLIONS PageOpen InstallCompleteDialog 2014/7/21:09:29:56 Mashhud STALLIONS === Setup ended === 2014/7/21:09:30:16 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:09:30:16 Mashhud STALLIONS Path_Length: 157 2014/7/21:09:30:16 Mashhud STALLIONS Current Directory I: 2014/7/21:09:30:16 Mashhud STALLIONS Launch 2014/7/21:09:30:16 Mashhud STALLIONS CommandLine 2014/7/21:09:30:16 Mashhud STALLIONS Path_Length: 157 2014/7/21:09:30:16 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI6228.tmp 2014/7/21:09:30:56 Mashhud STALLIONS === Setup ended === 2014/7/21:09:30:43 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:09:30:43 Mashhud STALLIONS Path_Length: 157 2014/7/21:09:30:43 Mashhud STALLIONS Current Directory I: 2014/7/21:09:30:43 Mashhud STALLIONS Launch 2014/7/21:09:30:43 Mashhud STALLIONS CommandLine 2014/7/21:09:30:43 Mashhud STALLIONS Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/21:09:31:01 Mashhud STALLIONS === Setup ended === 2014/7/21:09:30:34 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:09:30:34 Mashhud STALLIONS Path_Length: 157 2014/7/21:09:30:34 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI6228.tmp 2014/7/21:09:30:34 Mashhud STALLIONS Launch 2014/7/21:09:30:36 Mashhud STALLIONS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mashhud\AppData\Local\Temp\_AI6228.tmp\Setup\AcSetup.dll 2014/7/21:09:30:36 Mashhud STALLIONS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/7/21:09:30:56 Mashhud STALLIONS PageOpen LaunchDialog 2014/7/21:09:31:11 Mashhud STALLIONS PageOpen LicenseDialog 2014/7/21:09:31:14 Mashhud STALLIONS PageOpen ProductInfoDialog 2014/7/21:09:32:02 Mashhud STALLIONS PageOpen ProductSelectionDialog2 2014/7/21:09:32:18 Mashhud STALLIONS PageOpen FullProgressDialog 2014/7/21:09:32:18 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "I:\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2014/7/21:09:32:48 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2014/7/21:09:32:48 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "I:\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2014/7/21:09:33:48 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2014/7/21:09:33:49 Mashhud STALLIONS Installing Autodesk® ReCap™: INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,.NET Framework Runtime 4.0,;;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI6228.tmp\Media.mst" 2014/7/21:09:39:32 Mashhud STALLIONS Install Autodesk® ReCap™ Succeeded Reboot is required 2014/7/21:09:39:34 Mashhud STALLIONS Installing Autodesk® 360: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI6228.tmp\x64\Components\Cloudsync\AdSync-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:09:41:31 Mashhud STALLIONS Install Autodesk® 360 Succeeded Reboot is required 2014/7/21:09:41:31 Mashhud STALLIONS Installing Autodesk Application Manager: "I:\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe" 2014/7/21:09:47:48 Mashhud STALLIONS Install Autodesk Application Manager Succeeded 2014/7/21:09:47:49 Mashhud STALLIONS PageOpen InstallCompleteDialog 2014/7/21:09:58:30 Mashhud STALLIONS === Setup ended === 2014/7/21:09:58:37 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:09:58:37 Mashhud STALLIONS Path_Length: 157 2014/7/21:09:58:37 Mashhud STALLIONS Current Directory I: 2014/7/21:09:58:37 Mashhud STALLIONS Launch 2014/7/21:09:58:37 Mashhud STALLIONS CommandLine 2014/7/21:09:58:37 Mashhud STALLIONS Path_Length: 157 2014/7/21:09:58:37 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI56C3.tmp 2014/7/21:09:58:45 Mashhud STALLIONS === Setup ended === 2014/7/21:09:58:41 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:09:58:41 Mashhud STALLIONS Path_Length: 157 2014/7/21:09:58:41 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI56C3.tmp 2014/7/21:09:58:41 Mashhud STALLIONS Launch 2014/7/21:09:58:41 Mashhud STALLIONS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mashhud\AppData\Local\Temp\_AI56C3.tmp\Setup\AcSetup.dll 2014/7/21:09:58:41 Mashhud STALLIONS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/7/21:09:58:45 Mashhud STALLIONS PageOpen LaunchDialog 2014/7/21:09:58:46 Mashhud STALLIONS PageOpen LicenseDialog 2014/7/21:09:58:48 Mashhud STALLIONS PageOpen ProductInfoDialog 2014/7/21:10:00:20 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:10:00:20 Mashhud STALLIONS Path_Length: 157 2014/7/21:10:00:20 Mashhud STALLIONS Current Directory I: 2014/7/21:10:00:20 Mashhud STALLIONS Launch 2014/7/21:10:00:20 Mashhud STALLIONS CommandLine 2014/7/21:10:00:20 Mashhud STALLIONS Path_Length: 157 2014/7/21:10:00:20 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AIE72F.tmp 2014/7/21:10:00:30 Mashhud STALLIONS === Setup ended === 2014/7/21:10:00:23 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:10:00:23 Mashhud STALLIONS Path_Length: 157 2014/7/21:10:00:23 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AIE72F.tmp 2014/7/21:10:00:23 Mashhud STALLIONS Launch 2014/7/21:10:00:24 Mashhud STALLIONS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mashhud\AppData\Local\Temp\_AIE72F.tmp\Setup\AcSetup.dll 2014/7/21:10:00:24 Mashhud STALLIONS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/7/21:10:00:30 Mashhud STALLIONS PageOpen LaunchDialog 2014/7/21:10:00:31 Mashhud STALLIONS PageOpen LicenseDialog 2014/7/21:10:00:34 Mashhud STALLIONS PageOpen ProductInfoDialog 2014/7/21:10:01:09 Mashhud STALLIONS PageOpen ProductSelectionDialog2 2014/7/21:10:03:47 Mashhud STALLIONS PageOpen FullProgressDialog 2014/7/21:10:03:47 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "I:\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2014/7/21:10:04:01 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2014/7/21:10:04:01 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "I:\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2014/7/21:10:04:35 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2014/7/21:10:04:35 Mashhud STALLIONS Installing DirectX Runtime: "I:\3rdParty\DirectX\DXSETUP.exe" /silent 2014/7/21:10:05:57 Mashhud STALLIONS Install DirectX Runtime Succeeded 2014/7/21:10:05:57 Mashhud STALLIONS Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AIE72F.tmp\Media.mst" 2014/7/21:10:06:36 Mashhud STALLIONS Install Autodesk Material Library 2015 Succeeded 2014/7/21:10:06:36 Mashhud STALLIONS Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AIE72F.tmp\Media.mst" 2014/7/21:10:07:20 Mashhud STALLIONS Install Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/21:10:07:23 Mashhud STALLIONS Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS=I:\x64\en-us\Tools\snap\ContentService.mst;C:\Users\Mashhud\AppData\Local\Temp\_AIE72F.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:10:07:45 Mashhud STALLIONS Install Autodesk Content Service Succeeded 2014/7/21:10:07:45 Mashhud STALLIONS Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AIE72F.tmp\Media.mst" 2014/7/21:10:07:58 Mashhud STALLIONS Install Autodesk Content Service Language Pack Succeeded 2014/7/21:10:07:59 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015: TRANSFORMS="I:\x64\en-us\PLNT3D\PLNT3D.mst;C:\Users\Mashhud\AppData\Local\Temp\_AIE72F.tmp\x64\PLNT3D\PLNT3D-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:10:17:31 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Succeeded 2014/7/21:10:17:32 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015 Language Pack: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AIE72F.tmp\_laA382.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:10:18:51 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Language Pack Succeeded 2014/7/21:10:18:53 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015 Product Specific Pack: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AIE72F.tmp\_laA382.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:10:19:31 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Product Specific Pack Failed Installation aborted, Result=1602 2014/7/21:10:20:08 Mashhud STALLIONS Rollback Autodesk® AutoCAD® Plant 3D 2015 Language Pack Succeeded 2014/7/21:10:22:37 Mashhud STALLIONS Rollback Autodesk® AutoCAD® Plant 3D 2015 Succeeded 2014/7/21:10:22:40 Mashhud STALLIONS Rollback Autodesk Content Service Language Pack Succeeded 2014/7/21:10:23:03 Mashhud STALLIONS Rollback Autodesk Content Service Succeeded 2014/7/21:10:23:42 Mashhud STALLIONS Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/21:10:24:35 Mashhud STALLIONS Rollback Autodesk Material Library 2015 Succeeded 2014/7/21:10:24:36 Mashhud STALLIONS Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2014/7/21:10:24:36 Mashhud STALLIONS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2014/7/21:10:24:36 Mashhud STALLIONS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619 2014/7/21:10:24:37 Mashhud STALLIONS PageOpen InstallCompleteDialog 2014/7/21:10:25:55 Mashhud STALLIONS === Setup ended === 2014/7/21:10:52:12 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:10:52:12 Mashhud STALLIONS Path_Length: 157 2014/7/21:10:52:12 Mashhud STALLIONS Current Directory I: 2014/7/21:10:52:12 Mashhud STALLIONS Launch 2014/7/21:10:52:12 Mashhud STALLIONS CommandLine 2014/7/21:10:52:12 Mashhud STALLIONS Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/21:10:52:27 Mashhud STALLIONS Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/21:10:52:27 Mashhud STALLIONS Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/21:10:52:29 Mashhud STALLIONS === Setup ended === 2014/7/21:10:58:24 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:10:58:24 Mashhud STALLIONS Path_Length: 157 2014/7/21:10:58:24 Mashhud STALLIONS Current Directory I: 2014/7/21:10:58:24 Mashhud STALLIONS Launch 2014/7/21:10:58:24 Mashhud STALLIONS CommandLine 2014/7/21:10:58:24 Mashhud STALLIONS Path_Length: 157 2014/7/21:10:58:24 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI2B05.tmp 2014/7/21:11:00:07 Mashhud STALLIONS === Setup ended === 2014/7/21:10:59:46 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:10:59:46 Mashhud STALLIONS Path_Length: 157 2014/7/21:10:59:46 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI2B05.tmp 2014/7/21:10:59:46 Mashhud STALLIONS Launch 2014/7/21:10:59:49 Mashhud STALLIONS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mashhud\AppData\Local\Temp\_AI2B05.tmp\Setup\AcSetup.dll 2014/7/21:10:59:49 Mashhud STALLIONS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/7/21:11:00:07 Mashhud STALLIONS PageOpen LaunchDialog 2014/7/21:11:00:10 Mashhud STALLIONS PageOpen LicenseDialog 2014/7/21:11:00:13 Mashhud STALLIONS PageOpen ProductInfoDialog 2014/7/21:11:00:59 Mashhud STALLIONS PageOpen ProductSelectionDialog2 2014/7/21:11:01:30 Mashhud STALLIONS PageOpen FullProgressDialog 2014/7/21:11:01:31 Mashhud STALLIONS Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "I:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q 2014/7/21:11:02:28 Mashhud STALLIONS Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2014/7/21:11:02:28 Mashhud STALLIONS Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "I:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q 2014/7/21:11:03:01 Mashhud STALLIONS Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2014/7/21:11:03:04 Mashhud STALLIONS Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "I:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Mashhud\AppData\Local\Temp\vcredist_x86_2010.log 2014/7/21:11:03:22 Mashhud STALLIONS Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2014/7/21:11:03:22 Mashhud STALLIONS Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "I:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\Mashhud\AppData\Local\Temp\vcredist_x64_2010.log 2014/7/21:11:03:40 Mashhud STALLIONS Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2014/7/21:11:03:40 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "I:\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2014/7/21:11:05:12 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2014/7/21:11:05:12 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "I:\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2014/7/21:11:07:32 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2014/7/21:11:07:32 Mashhud STALLIONS Installing DirectX Runtime: "I:\3rdParty\DirectX\DXSETUP.exe" /silent 2014/7/21:11:08:50 Mashhud STALLIONS Install DirectX Runtime Succeeded 2014/7/21:11:08:51 Mashhud STALLIONS Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI2B05.tmp\Media.mst" 2014/7/21:11:09:19 Mashhud STALLIONS Install Autodesk Material Library 2015 Succeeded 2014/7/21:11:09:22 Mashhud STALLIONS Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI2B05.tmp\Media.mst" 2014/7/21:11:09:41 Mashhud STALLIONS Install Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/21:11:09:46 Mashhud STALLIONS Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS=I:\x64\en-us\Tools\snap\ContentService.mst;C:\Users\Mashhud\AppData\Local\Temp\_AI2B05.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:11:10:01 Mashhud STALLIONS Install Autodesk Content Service Succeeded 2014/7/21:11:10:02 Mashhud STALLIONS Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI2B05.tmp\Media.mst" 2014/7/21:11:10:14 Mashhud STALLIONS Install Autodesk Content Service Language Pack Succeeded 2014/7/21:11:10:15 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015: TRANSFORMS="I:\x64\en-us\PLNT3D\PLNT3D.mst;C:\Users\Mashhud\AppData\Local\Temp\_AI2B05.tmp\x64\PLNT3D\PLNT3D-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:11:17:14 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Succeeded 2014/7/21:11:17:16 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015 Language Pack: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI2B05.tmp\_la9765.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:11:19:09 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Language Pack Succeeded 2014/7/21:11:19:09 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015 Product Specific Pack: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI2B05.tmp\_la9765.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:11:19:38 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Product Specific Pack Failed Installation aborted, Result=1602 2014/7/21:11:19:59 Mashhud STALLIONS Rollback Autodesk® AutoCAD® Plant 3D 2015 Language Pack Succeeded 2014/7/21:11:21:27 Mashhud STALLIONS Rollback Autodesk® AutoCAD® Plant 3D 2015 Succeeded 2014/7/21:11:21:30 Mashhud STALLIONS Rollback Autodesk Content Service Language Pack Succeeded 2014/7/21:11:21:37 Mashhud STALLIONS Rollback Autodesk Content Service Succeeded 2014/7/21:11:22:13 Mashhud STALLIONS Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/21:11:22:51 Mashhud STALLIONS Rollback Autodesk Material Library 2015 Succeeded 2014/7/21:11:22:51 Mashhud STALLIONS Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2014/7/21:11:22:51 Mashhud STALLIONS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2014/7/21:11:22:51 Mashhud STALLIONS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619 2014/7/21:11:22:51 Mashhud STALLIONS Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2014/7/21:11:22:52 Mashhud STALLIONS Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2014/7/21:11:22:56 Mashhud STALLIONS PageOpen InstallCompleteDialog 2014/7/21:11:49:59 Mashhud STALLIONS === Setup ended === 2014/7/21:12:08:24 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:12:08:24 Mashhud STALLIONS Path_Length: 157 2014/7/21:12:08:24 Mashhud STALLIONS Current Directory I: 2014/7/21:12:08:24 Mashhud STALLIONS Launch 2014/7/21:12:08:24 Mashhud STALLIONS CommandLine 2014/7/21:12:08:24 Mashhud STALLIONS Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/21:12:08:26 Mashhud STALLIONS Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/21:12:08:26 Mashhud STALLIONS === Setup ended === 2014/7/21:12:08:34 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:12:08:34 Mashhud STALLIONS Path_Length: 157 2014/7/21:12:08:34 Mashhud STALLIONS Current Directory I: 2014/7/21:12:08:34 Mashhud STALLIONS Launch 2014/7/21:12:08:34 Mashhud STALLIONS CommandLine 2014/7/21:12:08:34 Mashhud STALLIONS Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/21:12:08:35 Mashhud STALLIONS === Setup ended === 2014/7/21:12:08:09 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:12:08:09 Mashhud STALLIONS Path_Length: 157 2014/7/21:12:08:09 Mashhud STALLIONS Current Directory I: 2014/7/21:12:08:09 Mashhud STALLIONS Launch 2014/7/21:12:08:09 Mashhud STALLIONS CommandLine 2014/7/21:12:08:09 Mashhud STALLIONS Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/21:12:08:50 Mashhud STALLIONS === Setup ended === 2014/7/21:12:09:02 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:12:09:02 Mashhud STALLIONS Path_Length: 157 2014/7/21:12:09:02 Mashhud STALLIONS Current Directory I: 2014/7/21:12:09:02 Mashhud STALLIONS Launch 2014/7/21:12:09:02 Mashhud STALLIONS CommandLine 2014/7/21:12:09:02 Mashhud STALLIONS Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/21:12:09:05 Mashhud STALLIONS Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/21:12:09:05 Mashhud STALLIONS === Setup ended === 2014/7/21:12:09:22 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:12:09:22 Mashhud STALLIONS Path_Length: 157 2014/7/21:12:09:22 Mashhud STALLIONS Current Directory I: 2014/7/21:12:09:22 Mashhud STALLIONS Launch 2014/7/21:12:09:22 Mashhud STALLIONS CommandLine 2014/7/21:12:09:22 Mashhud STALLIONS Path_Length: 157 2014/7/21:12:09:22 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI5283.tmp 2014/7/21:12:09:35 Mashhud STALLIONS === Setup ended === 2014/7/21:12:09:29 Mashhud STALLIONS === Setup started on STALLIONS by Mashhud === 2014/7/21:12:09:29 Mashhud STALLIONS Path_Length: 157 2014/7/21:12:09:29 Mashhud STALLIONS Current Directory C:\Users\Mashhud\AppData\Local\Temp\_AI5283.tmp 2014/7/21:12:09:29 Mashhud STALLIONS Launch 2014/7/21:12:09:29 Mashhud STALLIONS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Mashhud\AppData\Local\Temp\_AI5283.tmp\Setup\AcSetup.dll 2014/7/21:12:09:29 Mashhud STALLIONS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/7/21:12:09:35 Mashhud STALLIONS PageOpen LaunchDialog 2014/7/21:12:09:37 Mashhud STALLIONS PageOpen LicenseDialog 2014/7/21:12:09:40 Mashhud STALLIONS PageOpen ProductInfoDialog 2014/7/21:12:10:05 Mashhud STALLIONS PageOpen ProductSelectionDialog2 2014/7/21:12:10:11 Mashhud STALLIONS PageOpen FullProgressDialog 2014/7/21:12:10:11 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "I:\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2014/7/21:12:10:29 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2014/7/21:12:10:29 Mashhud STALLIONS Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "I:\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Mashhud\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2014/7/21:12:11:29 Mashhud STALLIONS Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2014/7/21:12:11:29 Mashhud STALLIONS Installing DirectX Runtime: "I:\3rdParty\DirectX\DXSETUP.exe" /silent 2014/7/21:12:13:15 Mashhud STALLIONS Install DirectX Runtime Succeeded 2014/7/21:12:13:16 Mashhud STALLIONS Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI5283.tmp\Media.mst" 2014/7/21:12:13:45 Mashhud STALLIONS Install Autodesk Material Library 2015 Succeeded 2014/7/21:12:13:48 Mashhud STALLIONS Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI5283.tmp\Media.mst" 2014/7/21:12:14:09 Mashhud STALLIONS Install Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/21:12:14:14 Mashhud STALLIONS Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS=I:\x64\en-us\Tools\snap\ContentService.mst;C:\Users\Mashhud\AppData\Local\Temp\_AI5283.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:12:14:30 Mashhud STALLIONS Install Autodesk Content Service Succeeded 2014/7/21:12:14:31 Mashhud STALLIONS Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI5283.tmp\Media.mst" 2014/7/21:12:14:38 Mashhud STALLIONS Install Autodesk Content Service Language Pack Succeeded 2014/7/21:12:14:38 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015: TRANSFORMS="I:\x64\en-us\PLNT3D\PLNT3D.mst;C:\Users\Mashhud\AppData\Local\Temp\_AI5283.tmp\x64\PLNT3D\PLNT3D-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:12:22:32 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Succeeded 2014/7/21:12:22:34 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015 Language Pack: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI5283.tmp\_la6040.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:12:24:02 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Language Pack Succeeded 2014/7/21:12:24:03 Mashhud STALLIONS Installing Autodesk® AutoCAD® Plant 3D 2015 Product Specific Pack: TRANSFORMS="C:\Users\Mashhud\AppData\Local\Temp\_AI5283.tmp\_la6040.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/7/21:12:24:33 Mashhud STALLIONS Install Autodesk® AutoCAD® Plant 3D 2015 Product Specific Pack Failed Installation aborted, Result=1602 2014/7/21:12:24:52 Mashhud STALLIONS Rollback Autodesk® AutoCAD® Plant 3D 2015 Language Pack Succeeded 2014/7/21:12:26:32 Mashhud STALLIONS Rollback Autodesk® AutoCAD® Plant 3D 2015 Succeeded 2014/7/21:12:26:34 Mashhud STALLIONS Rollback Autodesk Content Service Language Pack Succeeded 2014/7/21:12:26:48 Mashhud STALLIONS Rollback Autodesk Content Service Succeeded 2014/7/21:12:27:21 Mashhud STALLIONS Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/21:12:28:01 Mashhud STALLIONS Rollback Autodesk Material Library 2015 Succeeded 2014/7/21:12:28:01 Mashhud STALLIONS Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2014/7/21:12:28:01 Mashhud STALLIONS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2014/7/21:12:28:01 Mashhud STALLIONS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
