AutoCAD Plant 3D General DIscussion
Employee
rajsekarpillai
Message 21 of 26 (950 Views)
Re: AutoCAD Plant 3D Catalog Builder (Beta) is available now
02-08-2012 08:21 AM in reply to: ybogdanov
Spoiler
I checked with developer and he mentioned that you might be missed the environment path for the content builder.
1. Create a folder named “CustomScripts” under content folder C:\AutoCAD Plant 3D 2012 Content\CPak Common\ "
2. Create a custom python script, such as “TestScript.py” under the created folder.
Try this and let us know.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
EileenForan
Message 22 of 26 (936 Views)
02-09-2012 10:24 AM in reply to: GeorgeKamieniecki
Hi, George. Just to make sure you got the response (which is posted above your question), I'm reposting it here.
If this resolves your issue, can you please mark it as the accepeted solution? Otherwise, let us know if you are still having the issue, and we'll work on it some more to get you a fix.
thanks,
Eileen
Employee
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Eileen Foran
Community Program Manager
Autodesk Plant Solutions
GeorgeKamieniecki
Message 23 of 26 (934 Views)
02-09-2012 10:56 AM in reply to: rajsekarpillai
Hei,
I already have created the Custom Scripts folder and TestScript.py file.
In AutoCad Plant 3d I issued the command PLANTREGISTERCUSTOMSCRIPTS and got no error messages. The pyc file was created.
What I am unable to do is to run testacpscript as this command does not exist on my PC.
My other question is how do I access these scripts to actually create piping components in a Plant 3D model?
Regards
George K
GeorgeKamieniecki
Message 24 of 26 (764 Views)
05-18-2012 09:23 AM in reply to: EileenForan
I need to be able to define my own parametric piping components.  I followed the steps outlined in the instructions available last year without being able to get it working. There is a gap in my understanding of how to implement this functionality. Can you please send me an updated version of these instructions for Plant 3D 2013?
Regards
GK.
Employee
rajsekarpillai
Message 25 of 26 (752 Views)
05-21-2012 02:29 AM in reply to: GeorgeKamieniecki
The instructions are same for AutoCAD Plant3D 2013. please let us know if you need any specific example.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
GeorgeKamieniecki
Message 26 of 26 (619 Views)
10-01-2012 12:14 PM in reply to: RSFAdsk
I have been using Python scripts to create many new components without running into any showstoppers. Now I have hit on a problem with creating hex plugs and endcaps. The scripts compile OK and script testing gives the right results.
I am unable to introduce these components into a catalog. I suspect the problem has to do with group naming.
Attached is a zip file with the problem scripts.
Hopefully you can point me in the right direction
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
