AutoCAD Plant 3D General DIscussion
16 Kudos
Post 1 of 28
AutoCAD Plant 3D Catalog Builder (Beta) is available now
3037 Views, 27 Replies
09-06-2011 11:36 AM
CAD managers and expert users, create piping-component content quickly using the AutoCAD Plant 3D Catalog Builder (Beta):   www.autodesk.com/plantcatalogbuilder
Please feel free to leave your comments here or contact the plant content team directly: plant.content@autodesk.com
Eileen
Eileen Foran
Community Program Manager
Autodesk Plant Solutions
Valued Mentor
80 Kudos
Post 2 of 28
Re: AutoCAD Plant 3D Catalog Builder (Beta) is available now
09-06-2011 02:25 PM in reply to: EileenForan
One example, which is working. I probe to follow the steps of the tutorial and I have issue which I create .pyc file.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Employee
21 Kudos
Post 3 of 28
09-07-2011 08:31 AM in reply to: ybogdanov
Hi Yuri,
The sample PY that can be downloaded from the documentation page here: plantregistercustomscripts produces the PYC and supporting output files (image attached) for me on W7x64. The catalog builder can consume PYC scripts after they are registered.
If you are having problems, check that the folder name is "CustomScripts".  It needs to be created the first time (default path: C:\AutoCAD Plant 3D 2012 Content\CPak Common\CustomScripts).
The developer documentation and expertise necessary to create PY parametric scripts are beyond the scope of the Catalog Builder Beta.  But if the plantregistercustomscripts command does not work, possibly you can attach your PY.
Richard Frank
AEC Plant Solutions
Valued Mentor
80 Kudos
Post 4 of 28
09-07-2011 08:46 AM in reply to: RSFAdsk
Can you said me the python cript to create the rectangular pipe?
Yury Bogdanov
Barcelona (Spain)
Employee
21 Kudos
Post 5 of 28
09-07-2011 09:33 AM in reply to: ybogdanov
AP3D parametric shapes are available in compiled form, but not PY.  You can select the compiled shapes in the Part Family View for parametric components.  Specifically for square piping shape, that is not currently available.
Richard Frank
AEC Plant Solutions
16 Kudos
Post 6 of 28
09-22-2011 03:51 PM in reply to: EileenForan
Please note that that Catalog Builder on AutoCAD Plant Exchange has been updated to include custom python script example files and documentation updates.
You can find the updated Catalog Builder here:
http://autocad.autodesk.com/?nd=plantcatalogbuilder
Thanks. Comments are welcome.
Eileen
Eileen Foran
Valued Contributor
4 Kudos
Post 7 of 28
10-06-2011 07:29 AM in reply to: EileenForan
I Tray to Install Autocad Plant 3D Catalog Builder X86 in WinXP and DOES NOT WORK
Thanks.
DOES NOT WORK
DOES NOT WORK
DOES NOT WORK
DOES NOT WORK
DOES NOT WORK
DOES NOT WORK
16 Kudos
Post 8 of 28
10-06-2011 07:58 AM in reply to: batone79
Hi batone79:
Can you specIfy exactly what does not work?
Eileen
Eileen Foran
Valued Contributor
4 Kudos
Post 9 of 28
10-10-2011 04:02 AM in reply to: EileenForan
Hi thanks for your replay, but I tryed to intall X86 Catalog Builder in WinXP and can not start to Intall with a fatal Error, so, for me X86 catalog Builder Beta edition does not work. maybe X64 works.
Thanks..
Distinguished Contributor
5 Kudos
Post 10 of 28
10-20-2011 04:58 PM in reply to: batone79
 tried it also on Win7 x64, Both the 32 and 64 bit installer doesnt work
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
