The AutoCAD Plant 3D 2011 Hotfix 1 and AutoCAD P&ID 2011 Hotfix 1 are available now. The hotfxes address the following issues:
AutoCAD Plant 3D:
AutoCAD P&ID:
Isometric drawings - Corrected a problem that caused the display of a component's long description at the point of connection between two iso drawings. The drawing number of the connecting drawing is now displayed instead
In the future, I think it shold be better to have also the component description displayed as it was before. It would be accurate In cases where there are more connections related in between drawings/lines.
regards
We ran this hotfix on our sustem and the isometric fix did not work. we are still getting the long description on the connections. is there something that we are missing or something else that needs to be done?
Sounds like the hotfix is not installed correctly. Make sure you have the updated version of PnP3dIso.arx installed.
The file versions should be 2.0.137.100. PnP3dIso.arx should be in your program folder, along with acad.exe.
Sorry, I don't read the litle letters of the Hot-fix. And I installed it without Service Pack 1. In this case the ISOGEN don't work.
Hi bogdanov.y:
Did you get your issue regarding the hotfix resolved? Please let us know and we'll try to help you get to a resolution.
All the best,
Eileen
No, I don't resolve this problem. I needed reinstall program several times. Because if I install Plant3D with SP1 all work right. But in Spec editor there are any problems (actuator for example). When I go to install hot-fix the problem of Spec editor disapare, but the isogen don't work.
Hello bogdanov.y,
Can you check if you are installing the fixes in the right order?
If yes, then can you check if your PnP3dIso.arx file (in ACAD folder) got updated after you installed the Hotfix?
Raj.
The order is correct. Now I was copy this three files:
- PnP3dIso (version 2.0.137.0)
- PnP3dIsoRes (version 2.0.37.0)
- PnP3dIsoUI (version 2.0.137.0)
From PC that has Plant3D without Hot-Fix. And pasted those files in the notebook that has Plant3D with HotFix and SP1 (with problem in ISOGEN). And after this now ISOGEN work correctly...
Hello bogdanov.y,
It is good to know that you got ISOGEN working again. The AutoCAD Plant 3D 2011 Hotfix 1 is meant to fix an issue noticed during Iso creation:
Isometric drawings - Corrected a problem that caused the display of a component's long description at the point of connection between two iso drawings. The drawing number of the connecting drawing is now displayed instead.
If this is not a problem for you, you are all set. If not, please let us know so we can look into this further.
Raj.
Sorry another time, the problem finaly where that the path of server when I had my project contained the "at" (@). The project was working correctly but ISOGEN not. That's why I couldn't understand it because in the office of my client the ISOGEN didn't working and in my house the project working correctly. In the both cases I was using the same notebook.
P.S. I hope that in Plant3D 2012 that solution (Hot-fix) will be incorporated.
