AutoCAD Plant 3D Forum
AutoCAD Plant 3D 2014 Extension 2 posted on Subscription Center
23 REPLIES 23
Message 1 of 24
PeterQuinn
3093 Views, 23 Replies
Log into the Subscription Center to download the extension:
Autodesk® AutoCAD® Plant 3D 2014 Extension 2 is an extension to AutoCAD Plant 3D 2014 that adds the following functionality:
  • Fixed Length Pipe modeling
  • Revised modeling for stub ins with correct cut lengths
  • Revised P&ID assign tag dialog
  • Improved performance for P&ID Off Page connectors
In addition, there have been numerous improvements to isometric generation:
  • Annotation and dimensioning optimization
  • Improved drawing splitting
  • Fixed length Pipe graphics and BOM improvements
  • PCF Export enhanced to support custom end types
  • Numerous minor bug fixes
  • Ortho BOM no longer counts components marked with Existing status
  • Report Creator and Data Manager sort P&ID pipe sizes correctly
We have also addressed minor bug fixes not related to isometrics.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
23 REPLIES 23
Message 2 of 24
aldevos
in reply to: PeterQuinn
On the "Autodesk® AutoCAD® Plant 3D 2014 Extension 2" subscription webpage, there's a link to a "Readme - English (htm - 24Kb)".
This readme is the one of Extension 1... (see attached)
Could you please correct ?
Alexandre Devos
Message 3 of 24
eski
Yes, please attach the correct readme file for extension 2.  Thanks.
Message 4 of 24
dennis
I was hopeful that the 'Ortho bug' in creating projects from a project template would have been fixed in this extension, but it wasn't.
Overview of Ortho Bug:
I created a new project using no template, just the Default.  The Ortho folder created correctly as: Project 1 from Default \ Orthos \ with three subfolders off of Orthos: DWGs, Orthocube Library, and Styles.
Then I created a new project using as the project template the project first created using the Default that I just created.  The second project then had the folder structure: Project 2 \ Orthos \ DWGs \ with three subfolders off of DWGs: DWGs, Orhtocube Library, and Styles.
Message 5 of 24
Asimo5000
Do you need Extension 1 installed first?
Message 6 of 24
Peter_Jansoone
Peter, could you elaborate on the fixed pipe length ? I don't seem te get it to work !!
Peter Jansoone
Plant Design software consultant at Arkance Systems Belgium
Message 7 of 24
EricNyh
Looking at the Extension 2 iso updates, I noticed in the documentation there's an example for the LayoutOptimization settings in the updated xml file.  The example shows the "TargetPercentage" variable for DimensionOptimization and AnnotationOptimization.  The number is supposed to represent percentage, but one is shown as "25" and the other is shown as "0.25".  Is this correct?  Or is it a typo?  See attached png.
Message 8 of 24
ok, got the fixed pipe length working, you need to set the 'use fixed length' parameter in the Edit Parts table in Spec Editor. And you'll need to switch of the update from catalog optin for that field. I didn't find the property in Catalog Editor
Peter Jansoone
Message 9 of 24
richard.mouton
in reply to: Asimo5000
*Bump*
Do you need to Install Extension 1 first?
Message 10 of 24
dennis
in reply to: richard.mouton
I believe the answer is "yes" to install the Ext 1 first.
Message 11 of 24
ybogdanov
in reply to: dennis
After installing Ext2 in Plant3D 2014 Ext1 I cannot to open the program, FATAL ERROR.
 I reinstall Plant3D and turn to install Ext2 and I have the same problem. I use English version 64bits.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Message 12 of 24
PeterQuinn
in reply to: ybogdanov
You don't have to install Ext 1 before Ext 2. It should install on RTM 2014 or on Ext 1. If you've manally replaced any DLLs for hotfixes, put the originals back before installing.
Peter Quinn
Autodesk, Inc.
Message 13 of 24
Arun_Kumar_K
in reply to: EricNyh
whether automatic coupling will be placed using fixed length parameter?
Message 14 of 24
aldevos
Hello Peter,
I kindly ask again if you could correct the readme of Extension 2 which points to readme of Extension 1.
See the second post of this topic (http://forums.autodesk.com/t5/AutoCAD-Plant-3D/AutoCAD-Plant-3D-2014-Extension-2-posted-on-Subscript...)
Alexandre Devos
Tags (1)
Message 15 of 24
JohnHolder
regards to isometrics, has the error with flush bushings been addressed? ( sch 40 pvc )  They do not generate since there are negative lengths involved with the geometry.
Jason Drew is familar with the issue.
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Message 16 of 24
aldevos
So I need to open a case to Technical Support to get the readme ?
Why don't you answer to my question so it benefits to a bigger number of person ?
Alexandre Devos
Message 17 of 24
sziad
I'm using Autocad Plant 3D 2014 and I'm getting an error when I'm creating a new drawing.
Thank you
Message 18 of 24
MSpadaro
in reply to: Peter_Jansoone
what does you mean with "...And you'll need to switch of the update from catalog optin for that field. I didn't find the property in Catalog Editor " ?
Message 19 of 24
Peter_Jansoone
in reply to: MSpadaro
I did not find the toggle 'use fixed length' in Catalog editor, so you cannot switch it on there. If you switch the toggle in Spec Editor, it works fine., but when you run an update from catalog to spec, the toggle will be switched off again (I guess that's the default value in the catalog). So if you eliminate this field from the update, you can keep the value as set in spec Editor.
Peter Jansoone
Message 20 of 24
Peter_Jansoone
is it possible that extension 2 doesn't install when SP1 is installed ?
Peter Jansoone
”Boost
