we have created deployment for Autocad Plant 3D 2013 and to solve "Run as Admin" for shortcut "AutoCAD Plant 3D Spec Editor 2013" we are using "AutoCAD_Plant_3D_2013_x64_SP1.exe" service pack & "AutoCAD_Plant3D_2013_SP1_Data_Integrity_Hotfix_64bit".
After installing the above deployment when we launch the shortcut "AutoCAD Plant 3D 2013 - English" in standard user it goes for repair and shows error message "Run setup.exe to install Autocad Plant 3D 2013 - English" (Screenshot attached).
Even we tried modifying msi's & mst's present under folder ".\AdminImage\x64\PLNT3D\" by adding ISSETUPDRIVEN property and removing launch condition but still no luck.
Is anyone has faced this kind of issue?
Request you to response to above query ASAP.
