AutoCAD Plant 3D General DIscussion
Member
jlippincott
Message 1 of 4 (616 Views)
AutoCAD Plant 3D 2013 Off-Page Connector Hotfix Readme
616 Views, 3 Replies
10-08-2012 11:33 AM
Just installed this hotfix as per the Readme instructions. Now when I open my Plant 3d software It pops me the following error message:
Failed to Load Project File.
I've tried different project files, including the default one, and get the same error message. I tohught the dlls could somewhere be stuck in Wondws memory, so I shutdwon the computer and tried again. Still the same result.
Any Ideas?
Jeff
It appears the built in extraction tools from Win7 is causing the problem.
To fix this follow the steps below:
First:
Restore your system by copying back the original DLLs (If your DLLs were not backed up, use the DLLs in the attached ZIP file)
Verify that the project manager is working
Second:
Open the zipfile from the hotfix (http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19117194&linkID=14116968) using WinZip specifically, and use WinZip to extract the DLLs to a temporary location
Copy the DLLs into your installation.
Verify that the project manager is working.
Product Support
quentin.contreras
Message 2 of 4 (574 Views)
Re: AutoCAD Plant 3D 2013 Off-Page Connector Hotfix Readme
10-09-2012 02:36 PM in reply to: jlippincott
Try this:
Close out of Plant 3D and any other AutoCAD related tools. Run the following utility.
C:\Program Files\Autodesk\AutoCAD Plant 3D 2013 - English\PnPLocalDataCachePurger.exe
Let me know if this works
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Product Support
quentin.contreras
Message 3 of 4 (531 Views)
10-12-2012 04:55 PM in reply to: jlippincott
Have you been able to resolve your problem yet?
Quentin Contreras
Product Support
quentin.contreras
Message 4 of 4 (507 Views)
10-15-2012 02:25 PM in reply to: jlippincott
First:
Second:
Quentin Contreras
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
