In a continuing effort to provide high-quality products, Autodesk has released AutoCAD Plant 3D 2013 Service Pack 1 and AutoCAD P&ID 2013 Service Pack 1.
The service packs address many Isometric-related enhancements and modeling related to improve the productivity and accuracy.
NOTE: Before downloading the service packs, view the Readme.
AutoCAD Plant 3D 2013 Service Pack 1.
Thank you for the update.
I found it very useful!
I have a question however:
If I understand correctly the P3D will change the isoconfig.xml after I install the service pact to apply for example the continous weld numbering.
But if I have multiple projects I have to open all of my projects one by one to let the software update the config files?
this service pack doesn't seem to work with the Planf 3D 2013 extention
DarrenP
Hi
when I start the update I get this message, that tells me I don't have the correct product...but I have!
Read this first.
This update can be applied to only the English language release of AutoCAD Plant 3D 2013. If you are running the English language release, be sure to select the correct update (32-bit or 64-bit) for your software and operating system.
regards
Hartmut
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
the german version has been released: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20925490&linkID=14116968
DarrenP
