AutoCAD Plant 3D 2012 Service Pack is available now!
This service pack addresses the following issues:
Ortho Drawings
Spec Conversion
Sloped Pipe
Isometrics
Pipe Cutback Angle
Report Creator
Nozzle Tags
Plotting
Stretch Operation
Block Editing
We are waiting for the hotfix for the service pack 🙂
See attachment..
r.vandernd:
Thank you for reporting this issue. We are doing some testing here to figure out what might be causing this error. I'll let you know what I find out.
Meanwhile, can you tell me what OS you are installing on, and whether the original installation was via download or DVD?
Eileen
Eileen,
One system with Windows 7 Professional and a view systems with Enterprise.
All the systems are running on x64.
The installation comes from a Autodesk USB dongle.
Thanks, Robin
Hi there. The installation media (in your case, the USB) must be present when you install the service pack. Can you please check to see if that resolves the issue?
Eileen
Robin,
In order to help us track down this problem, can you please verify that you followed this procedure.
1 - insert the USB that the Plant 3D software was installed from
2 - Save the SP1 exe
3 - Right-click on the saved exe and select the 'Run as Administrator' option
If this does not resolve the problem, please let us see the error message(s).
Thank you for your patience.
Ian
Ian,
It will not work on our systems.
See the error in the attachment, the path with the folder 'Root' doesn't exist.
Robin
Can I get a version of P3D with SP1 integrated?
Or is it possible to slipstream the Service Pack into the installation files of P3D?
Robin
Hi again, Robin.
Ian Matthew is investigating your specific situation. We have been unable to reproduce the issue, though we have tried a few different scenarios.
I believe Ian has emailed you for more info. When we find a solution to your issue, we will post it to this thread so that anyone else with a similar issue can benefit from the resolution.
I hope this helps.
Eileen
Ms. Foran,
I installed this service pack and didn´t resolve my problem with tag´s.
See picture attached.
Best Regards,
Astakad
