AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
AutoCAD Plant 3D 2012 Service Pack is available now!
10 REPLIES 10
Message 1 of 11
EileenForan
1438 Views, 10 Replies
This service pack addresses the following issues:
Ortho Drawings
  • Corrected a problem that prevented flanges on flanged pipes from displaying in ortho drawings.
  • Corrected a problem that prevented polyface and polygon meshes from displaying on ortho drawings.
Spec Conversion
  • Corrected a problem where unexpected spaces caused problems during AutoPLANT spec conversion.
Sloped Pipe
  • Corrected a problem that made it impossible to place a flange at the intersection of a sloped pipe and an elbow.
  • Corrected a problem that caused a cutback elbow to become disconnected after using the plantpipeslope command.
Isometrics
  • Corrected a problem that caused changes made to title blocks to disappear.
  • Corrected a problem that prevented welds sizes from being exported to a PCF file properly.
Pipe Cutback Angle
  • Corrected a problem that caused the loss of the cutback angle when using the substitute grip.
Report Creator
  • Corrected a problem that prevented Report Creator from opening projects that require SQL authentication.
Nozzle Tags
  • Corrected a problem that caused nozzle tags to reset inappropriately after using the auditproject command.
Plotting
  • Corrected a problem that prevented wipeouts from displaying in a plotted drawing, although they displayed properly onscreen.
Stretch Operation
  • Modified the behavior of P&ID objects and schematic lines during a stretch operation to improve the user experience.
Block Editing
  • Corrected a problem that caused changes made to a specific block in the block editor to affect other blocks in the project.
  • Corrected a problem that caused a hidden line (added during a block edit or symbol edit) to be displayed as a continuous line when a drawing is printed or plotted.
Eileen Foran
Community Program Manager
Autodesk Plant Solutions
10 REPLIES 10
Message 2 of 11
r.vanderend
in reply to: EileenForan
We are waiting for the hotfix for the service pack 🙂
See attachment..
Message 3 of 11
EileenForan
in reply to: r.vanderend
r.vandernd:
Thank you for reporting this issue. We are doing some testing here to figure out what might be causing this error. I'll let you know what I find out.
Meanwhile, can you tell me what OS you are installing on, and whether the original installation was via download or DVD?
Eileen
Eileen Foran
Message 4 of 11
r.vanderend
Eileen,
One system with Windows 7 Professional and a view systems with Enterprise.
All the systems are running on x64.
The installation comes from a Autodesk USB dongle.
Thanks, Robin
Message 5 of 11
EileenForan
Hi there. The installation media (in your case, the USB) must be present when you install the service pack. Can you please check to see if that resolves the issue?
Eileen
Eileen Foran
Message 6 of 11
r.vanderend
Sorry it did'nt work for us..
Robin
Message 7 of 11
IanMatthew
Robin,
In order to help us track down this problem, can you please verify that you followed this procedure.
1 - insert the USB that the Plant 3D software was installed from
2 - Save the SP1 exe
3 - Right-click on the saved exe and select the 'Run as Administrator' option
If this does not resolve the problem, please let us see the error message(s).
Thank you for your patience.
Ian
Ian Matthew
Techinal Marketing Manager, Plant Solutions
Message 8 of 11
r.vanderend
in reply to: IanMatthew
Ian,
It will not work on our systems.
See the error in the attachment, the path with the folder 'Root' doesn't exist.
Robin
Message 9 of 11
r.vanderend
Can I get a version of P3D with SP1 integrated?
Or is it possible to slipstream the Service Pack into the installation files of P3D?
Robin
Message 10 of 11
EileenForan
Hi again, Robin.
Ian Matthew is investigating your specific situation. We have been unable to reproduce the issue, though we have tried a few different scenarios.
I believe Ian has emailed you for more info. When we find a solution to your issue, we will post it to this thread so that anyone else with a similar issue can benefit from the resolution.
I hope this helps.
Eileen
Eileen Foran
Message 11 of 11
astakad
Ms. Foran,
I installed this service pack and didn´t resolve my problem with tag´s.
See picture attached.
Best Regards,
Astakad
”Boost
