I'm currently trying to create a symbol like a Check Valve, everything is ok but, when I try to put the parameter "hasFlowDirection" to "True" after I click Ok, it returns to "False". This very disappointing me because I've tried this in on another project and it do the same thing. I've shearched around the net and I didn't find anything like this.
If someone can help me, I will be very happy.
Sébastien Voyer
I have the same issue with my Russian vesion of P&ID. When i choose "Истина"("true"), P&ID have to post in database value "true", but instead value "Истина" is posted. Interface can't recognise the value, and False is what we see in project preference window. when i changed value directly in database, everything worked correctly.
Ivan Pleshkov
sorry for my english
How did you do you change the value in Database ? Which file do you edit ?
Tank you and have a nice day.
Ivan, what table and what string did you changed. I've found out your blog but unfortunately the images won't load and I can't get to see what changes you did.
