AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
AutoCAD P&ID 2013...how to create flips and rotations on P&ID symbols
3 REPLIES 3
1083 Views, 3 Replies
Hi guys,
Is there anyone that has come across this or found a solution. Our company has recently moved onto P&ID and I have been given the task of creating the project template file.
My question is 'How do you add flip and rotations to P&ID symbol?' an eg is the end cap in AutoCAD P&ID, once inserted if you click the cap it gives you the option to flip it. I can't seem to get this to work and was wondering what is the process in doing so.
Craig.
3 REPLIES 3
Attila.Vallyon
Go to project settings:
PID DWG settings\PID class definition\
than select your item (engineering or non engineering item
And in the property name add the following:
HasFlowDirection
Type: Boolean
And set the default value to true
Now you can flip the direction of the symbol with selecting it and click on the small arrow.
Attila Vallyon
in reply to: Attila.Vallyon
Thanks mate...perfect, just what I was looking for. It is unfortunate that you don't get an option to rotate the symbol.
Attila.Vallyon
Yes. That is the only thing what works.
The P&ID symbols are not compatible with the dynamic blocks:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Custom-P-amp-ID-dynamic-blocks-not-working-once-added...
Attila Vallyon
”Boost
