Hello
If I have a device that was designed in AutoCAD and I want to attach pipes to it in AutoCAD Plant 3D is that possible?
I am also not able to get the pipe size as the whole size. Is these a possible way to have specific diameter for the pipe?
Thank you
You can create Plant 3D equipment from AutoCAD solids with the 'PlantEquipmentConvert' command. Once it is converted you can add nozzles to connect piping.
