AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
AutoCAD 2014 P & ID Drawing autogen properties
4 REPLIES 4
hussain
661 Views, 4 Replies
I have been using AutoCAD 2014 P & ID from last few days and facing a serious trouble in drawing autogen properties. I am not able to use last valve number as autogen property in custom valves . please help me for that.
4 REPLIES 4
C_Hill
in reply to: hussain
I'm having the same problem.. Autogen for valve numbers isn't working.
hussain
Hello Hill,
Do one thing give me your skype id .I will tell you how to do it?
Or you can check the below procedure
1.Go to project setup > P & Id drawing settings > P & ID Class definitions
2. Select Engineering Class > inline assets > Hand Valve
3.Select your hand valve class, on bottom left corner select tag format and click modify button
4.Select the target property and then select expression
5. Click no expression check box and then select autogenerate expression check box.
6. Select the desired autogenerate source (Project or Drawing) then click on the radio button below the desired field
7. Place the initial value for the properties if drawing field is selected else give increment also for project field in the properties defined in autogen property dialog box.
8. Place the valve and autogen numbering will start working
Imran
NeoN73
Hi i am having this probelm only with my custom valves all out of box ones work fine. i have set the tag modified to autogen etc also done it on the drawing fields and still nothing. what am i missing? i can get the line no. autogen to work fine, just not the valves.
Thanks Neo
hussain
in reply to: NeoN73
Neo tell me your Skype ID?
Imran Hussain Khan
”Boost
