I have a plain autocad 2014 3d model that I created and I am trying to convert it to a vessel within plant 3d, however it is not working. any suggestions?
Make your model a BLOCK first.
Select your block then go to *Home* then on the *Equipment* tab top right corner *Convert Equipment* click *Vessel* select your insertion point.
fill out the *long description* click properties then fill out as normal.
Make your model a BLOCK first - allows you to edit the block later after it is *equipment*
edited because I used chrome and it cleansed the post with fire... had to redo it in IE
