AutoCAD Plant 3D General DIscussion
Distinguished Contributor
53 Kudos
Post 11 of 24
Re: AutoCAD 2013 Service Pack 1.1 ( 64 bit )
12-19-2012 07:25 AM in reply to: gersteb
Thanks to Autodesk for brought the changes and released the Service Pack. Looking forward the 2014 release with many of our wishlist added.
Valued Mentor
18 Kudos
Post 12 of 24
12-27-2012 09:09 AM in reply to: gersteb
"Because you are assuming that trial Tetra 3D PDF is the reason here, check this application first."
I am in no way suggesting that the Tetra 3D PDF is the reason.
It causes a similar error. that is all.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Valued Mentor
18 Kudos
Post 13 of 24
12-27-2012 09:40 AM in reply to: gersteb
Downgraded the graphics card to autodesk cert. driver
reinstalled the service pack and still crashed.
Logitech keeps poping up in the crash note - the crash still happens with the software uninstalled.
it is NOT an option to permenantly uninstall my G13.
this is after a fresh format / re-install.
there is no software on the machine I can uninstall that is not essential to my workflow.
Master Yoda.
Valued Mentor
18 Kudos
Post 14 of 24
01-31-2013 10:13 AM in reply to: JohnHolder
  • Start - Run - MSCONFIG- Enter
  • On the general tab select the option 'diagnostic startup'
  • On the service tab check the box 'Hide all Microsoft services' and check 'FLEXNet Licensing Service 64', too
  • Now restart your computer.
  • Try to start Plant 3D
Also I deselected everything in startup - still crashes the computer.
Master Yoda.
Valued Mentor
18 Kudos
Post 15 of 24
02-06-2013 01:44 PM in reply to: JohnHolder
opening a support ticket.
Master Yoda.
Product Support
16 Kudos
Post 16 of 24
02-07-2013 07:30 AM in reply to: JohnHolder
Hi John,
One question here for understanding: You wrote at 18.12.:
Edit - Started it up under diag mode as recommended - no issues.
Now you tried it again but now you run into the failure?
Thank you
Bernd
Bernd Gerstenberger
Valued Mentor
18 Kudos
Post 17 of 24
02-07-2013 09:01 AM in reply to: gersteb
Re-tested it
but this time I was called away and by the time I came back - the crash happened.
Master Yoda.
Product Support
16 Kudos
Post 18 of 24
02-11-2013 01:27 AM in reply to: JohnHolder
Ok, John. In this case you have to make a clean uninstall and afterwards a reinstall. Look here for the steps for a clean uninstall: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617 . The installation is as normal.
Thank you
Bernd
Bernd Gerstenberger
0 Kudos
Post 19 of 24
03-19-2013 09:01 AM in reply to: JohnHolder
I am also having issues with this.
What versions should acui19res.dll be after the service pack?
I did a complete uninstall and reinstall and now find that I am having the same issue again.
Being intelligent is not a felony. But most societies evaluate it as at least a misdemeanor. - Heinlein
Valued Mentor
18 Kudos
Post 20 of 24
03-19-2013 09:05 AM in reply to: gersteb
yeah i basically gave up trying to install the service pack.
clean uninstall and reinstall did nothing.
Master Yoda.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
