I can not make attribute with center, even I change their property for center but it doesn't work. even with original template.
Regards Thai.
Solved by quentin.contreras. Go to Solution.
After the Iso is generated have you tried to run ATTSYNC command yet? Try running ATTSYNC to see if the text justifies correctly for you.
Quentin Contreras
Technical Support Specialist
This is an issue that has been actually been forwarded to our development team and they will be looking into the issue. In the meantime, continue to use ATTSYNC at this time until development is able to address this issue in a future update or release.
Quentin Contreras
I am having this same issue on all my isometrics, has there been any updates on this?
thanks
We fixed an issues that sounds similar in 2015 Ext 1.
