AutoCAD Plant 3D Forum
Attribute for ISO template
8 REPLIES 8
Message 1 of 9
thaipham
864 Views, 8 Replies
I can not make attribute with center, even I change their property for center but it doesn't work. even with original template.
Regards Thai.
8 REPLIES 8
Message 2 of 9
After the Iso is generated have you tried to run ATTSYNC command yet? Try running ATTSYNC to see if the text justifies correctly for you.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Message 3 of 9
thaipham
in reply to: thaipham
Yes it's work,
But the thing is we want to be auto generate drawing, that is the purpose of Iso. Because of a lot of Iso can be generate by a single project.
We appreciate that can be corrected in the future version.
Thanks for your answer.
Thai Pham
Dessinateur/Concepteur | Draftsman/Designer
Air Liquide Canada
T 514-846-3981 | T?L?C./F 514-846-3915
Thai.Pham@airliquide.com
[cid:image003.jpg@01CEF0F3.1A65A030]
CONFIDENTIALIT? - CONFIDENTIALITY Ce courriel est destin? exclusivement au(x) destinataire(s) mentionn?(s) ci-dessus et peut contenir de l'information confidentielle. Si ce message ne vous est pas destin?, veuillez le mentionner imm?diatement ? l'exp?diteur et effacer ce courriel sans en faire de copie. This e-mail message is intended only for the above named recipient(s) and may contain confidential information. If this message is not for you, please immediately notify the sender and delete this email message without making a copy.
Message 4 of 9
jabowabo
Attsync it in the template.
Message 5 of 9
jabowabo
When I make changes in the template I use BATTMAN on the title block and just sync everything before saving.
Message 6 of 9
thaipham
Yes, It did tried everything. but it is still not Sync.
thanks for following.
Message 7 of 9
This is an issue that has been actually been forwarded to our development team and they will be looking into the issue. In the meantime, continue to use ATTSYNC at this time until development is able to address this issue in a future update or release.
Quentin Contreras
Message 8 of 9
I am having this same issue on all my isometrics, has there been any updates on this?
thanks
Message 9 of 9
PeterQuinn
in reply to: jhallajian
We fixed an issues that sounds similar in 2015 Ext 1.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
”Boost
