I am trying to create a spec containing ASTM parts. When I load the ASTM catalog all the long descriptions are ASME instead of ASTM. Why is this? This means I have to change the long description so that the bill of materials on the isometric read ASTM.......Any ideas?
all family description family or size are in ASME??????
you can change the setting for your iso either to use the family or size
Basically -- Autocad Spec editor default catalogs do not include an astm catalog.....only asme catalog. It looks like our previous administrator installed astm catalog....at least named it astm catalog...however all the descriptions call out asme....not astm......Is there an astm catalog available for download? Or will I have to create my own?
If the content you require is currently unavailable you can request it here:
http://autocad.autodesk.com/?nd=plant_content_packs
If it is something that you need quickly then you should consider creating the content yourself.
Dan
