AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
AP3D2012 PCF export weld diameter missing
1 REPLY 1
695 Views, 1 Reply
Hi
I'm testing export pcf file to CAESAR (pipe stress analysis soft)
The PCF file generated by AP3D 2012 and imported in CAESAR give wrong diameters : diameter change (Apparently randomly)
Here after an extract of this PCF file.
In this same file and for weld bloc,  if I manualy replace 0.0000 at the end of each line by the right diameter 100.0000 the importation in CAESAR work perfectly
Any solution ?
extract of the  PCF file. :
ISOGEN-FILES  ISOGEN.FLS
UNITS-BORE  MM
UNITS-CO-ORDS  MM
UNITS-WEIGHT  KGS
UNITS-BOLT-DIA  MM
UNITS-BOLT-LENGTH  MM
PIPELINE-REFERENCE    8888
    ATTRIBUTE1  Test Project
    ATTRIBUTE2  8888
    ATTRIBUTE3
    ATTRIBUTE4
END-POSITION-NULL
    CO-ORDS          722.2962    -9275.7845    0.0000
END-POSITION-NULL
    CO-ORDS          43.7207    -9680.2382    0.0000
END-POSITION-NULL
    CO-ORDS          -236.0581    -10954.3898    0.0000
PIPE
    END-POINT        -236.0581    -10954.3898    0.0000    100.0000
    END-POINT        -236.0581    -10389.4920    0.0000    100.0000
    ITEM-CODE  CS300-1001
    FABRICATION-ITEM
    PIPING-SPEC  CS300
ELBOW
    END-POINT        -236.0581    -10389.4920    0.0000    100.0000  BW
    END-POINT        -83.6581    -10237.0920    0.0000    100.0000  BW
    CENTRE-POINT     -236.0581    -10237.0920    0.0000
    SKEY  ELBW
    ITEM-CODE  CS300-280
    FABRICATION-ITEM
    ANGLE   9000
    PIPING-SPEC  CS300
WELD
    END-POINT        -236.0581    -10389.4920    0.0000    0.0000
    SKEY  WW
    PIPING-SPEC  CS300
PIPE
    END-POINT        569.8963    -10237.0920    0.0000    100.0000
    FABRICATION-ITEM
    PIPING-SPEC  CS300
WELD
    END-POINT        -83.6581    -10237.0920    0.0000    0.0000
    SKEY  WW
    PIPING-SPEC  CS300
PIPE
    END-POINT        617.6483    -9680.2382    0.0000    100.0000
    END-POINT        43.7207    -9680.2382    0.0000    100.0000
    FABRICATION-ITEM
    PIPING-SPEC  CS300
Tags (1)
1 REPLY 1
Hi
Others test made with pcf importation to CAEPAIPE 6.5 ( trought PCF-to-CAEPIPE Translator) :
schedule and material missing by plant 3D in ITEM-CODE blocks in pcf export :
ISOGEN-FILES  ISOCONFIG.FLS
UNITS-BORE  INCH
UNITS-CO-ORDS  INCH
UNITS-WEIGHT  LBS
UNITS-BOLT-DIA  INCH
UNITS-BOLT-LENGTH  INCH
PIPELINE-REFERENCE    0001
    DATE-DMY 10/05/11
    ATTRIBUTE1
    ATTRIBUTE2
    ATTRIBUTE3
    ATTRIBUTE4
    ATTRIBUTE5
    ATTRIBUTE6
    ATTRIBUTE7  0001
    ATTRIBUTE8
    ATTRIBUTE9  Project Test
    PROJECT-IDENTIFIER
    REVISION  0
    AREA
    PIPING-SPEC  CS300
    INSULATION-SPEC
    TRACING-SPEC
END-POSITION-NULL
    CO-ORDS          -170.6921    225.9273    0.0000
END-POSITION-NULL
    CO-ORDS          -65.4749    100.0743    0.0000
ELBOW
    END-POINT        -170.6921    156.0157    0.0000    4.0000  BW
    END-POINT        -164.6921    150.0157    0.0000    4.0000  BW
    CENTRE-POINT     -170.6921    150.0157    0.0000
    SKEY  ELBW
    ITEM-CODE  CS300-280
    ITEM-DESCRIPTION  ELL 90 LR, BW, ASME B16.9, ASTM A234 Gr WPB SMLS, Sch 40
    FABRICATION-ITEM
    ANGLE   9000
    PIPING-SPEC  CS300
    TRACING-SPEC
    COMPONENT-ATTRIBUTE1   BOMCOLUMN_Material_CS
    COMPONENT-ATTRIBUTE2   BOMCOLUMN_SCHClass_40
WELD
    END-POINT        -170.6921    156.0157    0.0000    0.0000
    SKEY  WW
    FABRICATION-ITEM
    PIPING-SPEC  CS300
    TRACING-SPEC
PIPE
    END-POINT        -170.6921    225.9273    0.0000    4.0000
    ITEM-DESCRIPTION  PIPE, SEAMLESS, PE, ASME B36.10, ASTM A106 Gr B SMLS, Sch 40
    FABRICATION-ITEM
    PIPING-SPEC  CS300
    TRACING-SPEC
SUPPORT
    CO-ORDS          -170.6921    196.8476    0.0000    0.0000
    SKEY  01HG
    ITEM-CODE  SUPPORT, TS-1-4
    ITEM-DESCRIPTION  SUPPORT, TS-1
    FABRICATION-ITEM
    SUPPORT-DIRECTION  UP
    TRACING-SPEC
PIPE
    END-POINT        -71.4749    150.0157    0.0000    4.0000
    FABRICATION-ITEM
    PIPING-SPEC  CS300
    TRACING-SPEC
SUPPORT
    CO-ORDS          -114.8662    150.0157    0.0000    0.0000
    SKEY  01HG
    FABRICATION-ITEM
    TRACING-SPEC
WELD
    END-POINT        -164.6921    150.0157    0.0000    0.0000
    SKEY  WW
    FABRICATION-ITEM
    PIPING-SPEC  CS300
    TRACING-SPEC
ELBOW
    END-POINT        -65.4749    144.0157    0.0000    4.0000  BW
    END-POINT        -71.4749    150.0157    0.0000    4.0000  BW
    CENTRE-POINT     -65.4749    150.0157    0.0000
    SKEY  ELBW
    ITEM-CODE  CS300-280
    FABRICATION-ITEM
    ANGLE   9000
    PIPING-SPEC  CS300
    TRACING-SPEC
WELD
    END-POINT        -71.4749    150.0157    0.0000    0.0000
    SKEY  WW
    FABRICATION-ITEM
    PIPING-SPEC  CS300
    TRACING-SPEC
PIPE
    END-POINT        -65.4749    100.0743    0.0000    3.0000
    END-POINT        -65.4749    140.0000    0.0000    3.0000
    ITEM-CODE  CS300-998
    FABRICATION-ITEM
    PIPING-SPEC  CS300
    TRACING-SPEC
SUPPORT
    CO-ORDS          -65.4749    114.6803    0.0000    0.0000
    SKEY  SPRG
    ITEM-CODE  SUPPORT-4
    FABRICATION-ITEM
    TRACING-SPEC
REDUCER-CONCENTRIC
    END-POINT        -65.4749    140.0000    0.0000    3.0000  BW
    SKEY  RCBW
    ITEM-CODE  CS300-859
    ITEM-DESCRIPTION  REDUCER (CONC), BW, ASME B16.9, ASTM A234 Gr WPB SMLS, Sch 40
    FABRICATION-ITEM
    PIPING-SPEC  CS300
    TRACING-SPEC
WELD
    END-POINT        -65.4749    140.0000    0.0000    0.0000
    SKEY  WW
    FABRICATION-ITEM
    PIPING-SPEC  CS300
    TRACING-SPEC
WELD
    END-POINT        -65.4749    144.0157    0.0000    0.0000
    SKEY  WW
    FABRICATION-ITEM
    PIPING-SPEC  CS300
    TRACING-SPEC
MATERIALS
ITEM-CODE  CS300-280
    Schedule  40
    PressureClass
    Material  CS
ITEM-CODE  Buttweld-4
    Schedule
    PressureClass
    Material
    Schedule  40
    PressureClass
    Material  CS
ITEM-CODE  CS300-859
    Schedule  40
    PressureClass
    Material  CS
ITEM-CODE  CS300-998
    Schedule  40
    PressureClass
    Material  CS
    Schedule
    PressureClass
    Material
ITEM-CODE  SUPPORT-4
    DESCRIPTION  SUPPORT
    Schedule
    PressureClass
    Material
”Boost
