See attached images, the orientation of the actuator on angle valves comes out 90 degrees from where it should, how can I fix this ? The actuator orientations for inline valves show as they should.
Can you send me a copy of your model & the iso you have generated and your isoconfig.xml file. I will take a look and get back to you on this.
I am in amazement that you are able to get the angle valve to show up in the correct orrientation let a lone the actuator. I ended up making custom blocks and editing the IsoSkeyAcadBlockMap.xml. I just learned today that TYPE=Valve-Angle will make the out of box iso angle valves look correct.
Can you please look at this problem with plant3d isometric actuator orientations.
Can you please look at this problem to see if there is a solution, let me know if you need more information and/or files to accomplish this.
