Hi Everbody
Is it possible to set the dimensions in ISO drawings to get dual dimesions such as mm and inch together. Like in dimstyle set to Alternate dimesions on in Autocad.
Best Regards
Yes this can be done. If you go to your Isogen folder in P3D you will find an *.opl file in every Isogen type folder. This opl file allows you to set switches on and off (or other functions). Switch 9 is used to control the dimension form and position 7 in this switch is used to use metric and imperial dimensions.
Best way to go,
- Open the desired opl file
- look for switch 9
- if there is only one value (for instance 0) remember it as this i position nr. 1.
- If there are more, write them down
- the build-up of the switch positions is as follows 987654321 were each switch could have a value like 0, 1, etc.
- in your case position 7 should be one
For example, switch 9 could look like 1000000 (all is zero, except position 7) 1 activates double dimensioning
Good luck,
BJ
Hi
I have installed isogen utils instead of modifying OPL file directly and try to find following issues
1- pipe lengths in Metric and Inches together in Material List
2- co-ordinates and elevations in Metric and Inches together
It seems there is no option switches for them am I correct
Best Regards
