AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
After Deleting non used Specs
6 REPLIES 6
Ahmed1081975
473 Views, 6 Replies
Hi Support Team,
 I have one Issue with DIN Catalog and specs, I made one Spec DIN for Pressure Class P16 i get the copy from Existing Specs Call ( 16HS01.pspx ) and I add some Item And Delete some Other Items in the Spec file
After that i Start Working without Any Problems, but in the folder of SpecSheet I have many and I Deleted non used Specs, after that I try to Work in the model give me Massage About the connection and Port ....., it mean the model not working fully related the Spec sheet I have done it. How I know from where reading the other items specs and how I solve the Problem. For more Clarification Refer the screen shot in the attached file
Ahmed Helal
6 REPLIES 6
Dan.Scales
in reply to: Ahmed1081975
Hi Ahmed,
The error message seems to be saying that you do not have the required gasket for the joint in the spec.
Dan
Dan Scales
Ahmed1081975
in reply to: Dan.Scales
Thanks Dan,
PLs, find the attached file For Screen Shot in My specs,
PLs, Advice
Ahmed Helal
Dan.Scales
Hi Ahmed,
Would you be happy to share a copy of your spec?
Dan
Dan Scales
Ahmed1081975
Yes Of Course
Find the attached SPec File
Ahmed Helal
Dan.Scales
Hi Ahmed,
The spec does not contain bolts or gasket with the required property match for the RF facing to connect the parts.
You should be able to confirm this by removing the facing requirement:
Dan
Dan Scales
Ahmed1081975
Thanks Dan,
I solve my Issue by another Way By Chance
Just I Made Update Specs From the Autocad then solved.   Smiley Wink
Spoiler
”Boost
