AutoCAD Plant 3D General DIscussion
Ahmed1081975
Message 1 of 7 (186 Views)
After Deleting non used Specs
186 Views, 6 Replies
02-07-2013 02:56 AM
Hi Support Team,
 I have one Issue with DIN Catalog and specs, I made one Spec DIN for Pressure Class P16 i get the copy from Existing Specs Call ( 16HS01.pspx ) and I add some Item And Delete some Other Items in the Spec file
After that i Start Working without Any Problems, but in the folder of SpecSheet I have many and I Deleted non used Specs, after that I try to Work in the model give me Massage About the connection and Port ....., it mean the model not working fully related the Spec sheet I have done it. How I know from where reading the other items specs and how I solve the Problem. For more Clarification Refer the screen shot in the attached file
Ahmed Helal
Thanks Dan,
I solve my Issue by another Way By Chance
Just I Made Update Specs From the Autocad then solved.   :smileywink:
Spoiler
Product Support
Dan.Scales
Message 2 of 7 (161 Views)
Re: After Deleting non used Specs
02-08-2013 09:45 AM in reply to: Ahmed1081975
Hi Ahmed,
The error message seems to be saying that you do not have the required gasket for the joint in the spec.
Dan
Dan Scales
Ahmed1081975
Message 3 of 7 (155 Views)
02-08-2013 10:03 AM in reply to: Dan.Scales
Thanks Dan,
PLs, find the attached file For Screen Shot in My specs,
PLs, Advice
Ahmed Helal
Product Support
Dan.Scales
Message 4 of 7 (143 Views)
02-10-2013 07:45 AM in reply to: Ahmed1081975
Hi Ahmed,
Would you be happy to share a copy of your spec?
Dan
Dan Scales
Ahmed1081975
Message 5 of 7 (139 Views)
02-10-2013 09:35 AM in reply to: Dan.Scales
Yes Of Course
Find the attached SPec File
Ahmed Helal
Product Support
Dan.Scales
Message 6 of 7 (122 Views)
02-12-2013 09:30 AM in reply to: Ahmed1081975
Hi Ahmed,
The spec does not contain bolts or gasket with the required property match for the RF facing to connect the parts.
You should be able to confirm this by removing the facing requirement:
Dan
Dan Scales
Ahmed1081975
Message 7 of 7 (116 Views)
02-12-2013 11:22 AM in reply to: Dan.Scales
Thanks Dan,
Spoiler
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
