AutoCAD Plant 3D General DIscussion
Valued Mentor
tmccar
Message 1 of 3 (478 Views)
Adding tube fitting components to spec
478 Views, 2 Replies
12-12-2012 09:12 AM
I am setting up a pipe spec which uses Swagelok tube fittings with the "two-ferrule, mechanical grip design". There is a front and back ferrule which are enclosed in a nut. A seal is formed when the nut tightens on the 2-ferrule assembly.
   I was wondering how to represent it in a pipe spec. Should I keep all the components seperate, what "end conditions" should I use for the ferrules and would this sort of connection come under a "flanged" or "collared"  auto-joint in Plant?
Active Contributor
rchiasson
Message 2 of 3 (469 Views)
Re: Adding tube fitting components to spec
12-12-2012 02:41 PM in reply to: tmccar
The connections are still basically threaded connections. We used these in AutoPLANT and I just built them using threaded fittings. I don't see a need to build them as a special connection since they are still male and female connections. You will just need to build the components per the cut sheets. There might have to be a work around for some of the components, but the general tube, fittings and valves should function just fine.
Valued Mentor
tmccar
Message 3 of 3 (463 Views)
12-12-2012 03:37 PM in reply to: rchiasson
OK, thanks. What "end condition" did you use? THDM?  And how many ports (1 or 2)?
Tom
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
