Is it possible to add Pipe Service Designations? And/or modify existing ones? We have quite a few that we need to input, ie - NGL, VNT, EGL, EGR.
Thank you, Evie
Yes, the Services are a list in the Project Setup. To get to that, expand down to where you can select List in the Property Type and then select Services. I attached a png to show you the interface...cuz for me, a picture does indeed paint a thousand words.
The best thing is to bastardize their existing service list, especially if you plan on using P&ID -> P3D group mapping, and then Layer or Color by Service.
I found that with lots of testing using custom properties or new selection lists, the P&ID -> P3D mapping didn't work unless I just reused their list.
