I would like to add a custom isometric template (A1) to Autocad Plant 3D 2013. What is the proper procedure for adding the custom template?
Thank you
This is done in the Project Setup/Isometric DWG Settings/Iso Style Setup.
Check out this useful help article: To create or change an isometric style
http://docs.autodesk.com/PLNT3D/2014/ENU/filesPLNT3D/GUID-503D4236-7394-4CA2-8416-D71EF24F1292.htm
