AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Adding custom isometric template to Autocad Plant 3D
1 REPLY 1
david.flores
957 Views, 1 Reply
I would like to add a custom isometric template (A1) to Autocad Plant 3D 2013. What is the proper procedure for adding the custom template?
Thank you
1 REPLY 1
This is done in the Project Setup/Isometric DWG Settings/Iso Style Setup.
Check out this useful help article: To create or change an isometric style
http://docs.autodesk.com/PLNT3D/2014/ENU/filesPLNT3D/GUID-503D4236-7394-4CA2-8416-D71EF24F1292.htm
Martin Stewart
AEC Support Specialist
”Boost
