AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Add Service to existing list
4 REPLIES 4
dennis
2849 Views, 4 Replies
I want to setup layers and color to be by Service, which is easy enough in Project Setup/Plant3D DWG Settings/Layer and Color Settings.  However, not all the abbreviations are available of the Services we need to "layer and color".  I cannot find how to add to the exisitng list of Service.  Can someone point me in the right direction?
4 REPLIES 4
dennis
in reply to: dennis
Found it.
GoTo Project Properties/ Plant 3D Class Definitions /P3d Line Group
Then highlight Service on the right-side and pick the edit button.
in reply to: dennis
tHANKS, THIS IS WHAT I NEEDED ALSO.
in reply to: dennis
I have followed this procedure and the added service is visible in the project setup, but when i am assigning the pipe tag in the P&ID I cannot find the added service in the drop down list.
I cannot understand what the error message wants to convey.
Tags (2)
nedeljko.sovljanski
I hope is not too late for answer. I just had same problem and this is solution:
Project Setup > P&ID Class Definitions > Pipe Line Group, in properties table find and select Services row. Click on edit and add your service.
Now you will see your service in P&ID drawings.
Best regards
”Boost
