in the spec editor, is it possible to create a new group title?
I have a lot of different types of valves which are all under the group title 'Valves'. When I create a tool pallet from the spec, all my valves are under the 'Valves' heading.
I want to be able to add new group titles in the spec editor so I can split up my valve symbols into different categories which will then transfer to the tool pallette.
Well, no.
If you open the catalog editor, click on create new component, than you can see what the component classes are (fittings, miscellaneous, olet,...) and within whate the types are.
You can manually edit your tool palettes though. Or create a new one and export, import. If it helps...
