currently the project manager has 3 tabs -
Source Files
Orthographics DWG
Isometric DWG
Is it possible to add more tabs and folder locations to this? i.e. for different types of drawings (1 tab for vessel detail drawings, 1 tab for valve manifold drawings etc)
Solved by phil.cooper. Go to Solution.
No
just inside " Source Files" you can do this
cw
ok, i have created more folders in the ortho tab. but in the properties of the folder, when i try to tell it to save the drawings in a certain folder. it comes up with the error message saying the file cannot be found. (see attachment).
Why would this be happening?
sorted it, it was because of the space after the number in the folder name -
I had it named -
09. GEA Sketches
it should be -
09.GEA Sketches
works now.
i told you 😉 you will get trouble with that
