AutoCAD Plant 3D General DIscussion
thebearjed
Message 1 of 3 (300 Views)
Add handlever to custom valve?
300 Views, 2 Replies
04-24-2012 07:00 AM
i have created a custom ball valve using the CREATE NEW COMPONENT in the catalog editor using PLANT 3D PARAMETRICS GRAPHICS. when i click on EDIT OPERATOR ASSIGNMENTS my valve does not show up in the list so that i can add a handlever to the valve?
You'll want to make sure you setup the new valve as a 'valve body'
Go ahead and save the new valve once you entered the required info. Next, click on the 'Edit Operator Assignments' button and select your new valve from the 'Valve Part Family' drop-down list:
From there you should be able to assign an operator for each size.
thebearjed
Message 2 of 3 (282 Views)
Re: Add handlever to custom valve?
04-26-2012 10:35 AM in reply to: thebearjed
knock knock...
Product Support
jason.drew
Message 3 of 3 (279 Views)
04-26-2012 12:01 PM in reply to: thebearjed
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
