Hi there,
I am wondering if anyone has any ideas on how to add a custom message tag to the drop down list in the image below? I know how to create the block etc, but i am interested in knowing how to add custom messages to this list, i.e. i would like to see 'Termination Point' in this list which would refer to a custom block. The messages are very generic, maybe thats deliberate, however i feel it would be good if users could customise this list.
Cheers
This isn't what you asked, but it give you want you want.
http://www.pdoteam.com/2013/08/notes-on-supports-in-plant-3d-isometrics/
Cheers Dave,
I have seen that paper before and implimented it for supports, supports were quite easy though, as a filter could be easily created and applied solely to supports. Whereas with a termination point we have a number of items which could apply, and we don't want the message to appear everytime that item is found. Adding to the drop down list is the most user friendly way we can think of / see.
Guessing no-one has any ideas on how to add to that list?
I don't know if it's possible to add to the default list but it is possible to create and edit Iso messages with the API. You can insert any message you like and even change the 3d block to whatever you want.
Thanks for the response, however, i am specifically looking to edit, preferrably add to the standard list. I have created several custom blocks so i am fairly well versed in creating custom blocks this way.
Essentially all i want is a symbol (node) to come in at my desired location as per the standard iso messages do. I don't want to have to apply symbols and messages as per a filter. This is too specific. The easiness of the user being able to add a message at his/her chosen location is what we are looking for.
Those values are hard coded. I don't think that is going to be an option.
Maybe you could accomplish nearly the same thing with custom supports, messages and symbols. Maybe a wonky idea, but it could work. You can define the symbol to be inserted, and you would have control over the placement, and symbol output on the iso.
That is an interesting idea Dave, thanks.
I will have a play aroud with that theory tomorrow and post back here to let you all know.
Cheers
richard.imrie wrote:Essentially all i want is a symbol (node) to come in at my desired location as per the standard iso messages do. I don't want to have to apply symbols and messages as per a filter. This is too specific. The easiness of the user being able to add a message at his/her chosen location is what we are looking for.
This API, looks good, is this an additional feature? Labs?
Available in 2014?
Never seen this before, can someone help with how this works.
Cheers
Here's a good blog post introducing the Plant 3D API.
http://adndevblog.typepad.com/autocad/2012/10/getting-started-with-autocad-pidplant-3d-2013-api.html
