AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Actuators in Pipe Spec
1 REPLY 1
383 Views, 1 Reply
I added an Actuator to a piping spec, but it does not appear anywhere in the spec. Where sould the actuator be listed?
Thank you
DF
1 REPLY 1
GSC_HAYA
Hello
You can find the actuators here (german version): Rohrklassen\DIN-Wandstärken zuweisen...(piping classes\wall thickness...). Then you can see the form like in the attachment.
Delete an actuator (earlier answer form here):
You can do this by opening the spec with SQLite DatabaseBrowser but this is not unperilous and not supported. So be aware that you have made a copy of the two spec files (*.pspx and *.pspc). In SQLite DatabaseBrowser you have to look for the tables 'ValveActuator', 'ValveActuatorMap' and 'EngineeringItems'. There you can look for your actuators and delete them.
Guido
Plant3D 2022 German
WIN10 Pro
”Boost
